tashas <3 944's Avatar
Porsche Crest helpfull hints for 944 newbie
Hello,
I recently acquired a 84 944. I know it needs a new clutch, paint, interior, tires, rotors, pads, calibers..... so far. We will know more after firing, or attempting to other issues with the engine. We have a clutch. Once we install that we will go forward from there. Are there any helpful hints that you would like to share with me and some of the vices and ticks that seem to be a normal issue with this car.
Also, if you have something to offer that you may think we need.... go right ahead. I believe we are in for quite a project!
I would like to inquire about opinions on some of the best part manufacturers aside from porsche.
Thanks!
Old 04-21-2011, 04:07 AM
porsche1st's Avatar
I know this web site has tons of after market Porsche parts but it's very pricey LINDSEY RACING - Your Porsche Performance Parts Center and yeah it does sound like you have a large project tashas, also be sure the oil cooler is in good condition, to tell if its bad you'll have a brown "milkshake" in your coolant (i know from experience), which is very common on the 944 to go bad.
Old 04-21-2011, 04:50 AM
yarfk
kfray's Avatar
Clark's Garage Shop Manual can be very useful in repairing your car.
Clark's Garage Home Page
------Keith------kfray------yarfk-------
87 944 NA stock 116k
06 Honda Ridgeline 83k
10 Vibe 2.4 AWD (Wife's)
Retired My week consist of Saturdays and Sundays
Old 04-21-2011, 05:04 AM
Welcome tashas, there also also 944online.com for new and used 944 parts. How long has it been since the car ran? If quite awhile take the time and pull timing belt covers to check belts and rollers before starting. If belts and w/p have not been changed , do it (at least the belts) as a broken belt will result in bent valves. Clean all grounds. Pull each fuse and clean ends as well as holders for them. Pull relays and re-seat for good connections.
It does sound like quite a project. As I have heard before a cheap porsche is usually a very expensive porsche, or you are only $8,000 from a $5,000 car. (these apply to me also, but I really like the cars)
'73 914 2.0, '84 944 coupe, '87 944 coupe, '90 944s2 cabriolet, '81 928, '86.5 928s, '71 corvette, '84 corvette
Old 04-21-2011, 05:17 AM
Proprietoristicly Refined
John_AZ's Avatar
Originally Posted by tashas <3 944 View Post
Hello,
If you can use a wrench, labor is cheap. If you need a pro, labor rates start at $72 an hour and max at the Porsche Dealer.
If you plan to do all the work in your first post, plan for weeks of down time.
All of the normal parts can be purchased from our sponsor, Pelican. Check here first.
Thanks!
Use the Elring RMS (rear main seal).
Search for installation tips.
Welcome & GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 04-21-2011, 06:04 AM
ernie9944's Avatar
Welcome & GL
John
First welcome to Pelican one of the best & helpful forum there is for a new Porsche owners,second like mention check your timing /balance shafts belts ASAP.Third one of the best uses part site is rigth here (924/944/968 Used Parts Classified) or Rennlist.com .Agree with John Pelican got one of the best supply of new parts for our car "Good service- no hassle with shipping & very decent price if you compare to any other suppliers"Have fun wrenching.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 04-21-2011, 06:19 AM
Porsche Crest
Okay..... thanks so much for the replies. I am a newbie with the Porsch and with wrenching. Well I can do some small matenience. :-) this car is my first hands on project so naturally I am trying to educate myself as much as I can about this model and what others think are the best products and so forth. I have a great support team to back me up, thank god, or this car would never make it. My boyfriend is an amazing mechanic and his best friend wrenches for Porsche in Pasadena. So thank goodness I don't have to pay for labor..... the parts are more than expensive enough! I don't want to race it, though I am not a complete purist either...... like all of you, I just want to end up with one bad ass car! And can actually say I was the main reason it got that way!
Thank you again for your help and info.
Old 04-21-2011, 09:14 PM
Welcome to the forum
I would say Timing and balance shaft belts and the other components that are in there like belt rollers, water pump and seals should be checked over like others have mentioned. Because if those fail you will have to do a lot more work.
Timing belts ear easy to do even yourself but the right tools make it easier, heck there are even videos on youtube about it.
Buy you're parts from pelican as you need them. Prices are great, navigation to the parts is great, and since you're in socal and Pelican has a warehouse there it shouldent take more then 2days to get to you. And they process you're order very quickly and not a few days later like some places on the net.
If i place an order from 8-11am it gets processed and shipped in about an hour FAST!
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 04-21-2011, 11:45 PM
Get the car sorted and running good first before you start with the lindsey goodies.....
Old 04-22-2011, 05:59 AM
ernie9944's Avatar
+1 agree 100% with you Sidney,maintenance with the proper OME parts (if possible) is a must to get your car well sorte out .
Old 04-22-2011, 06:09 AM
Plus modding a car to full on bat schit insane gets pricey... I'd wager to guess I dropped more on my suspension last year than the OP paid for their car....
Buy OEM or OEM quality parts from a reputable supplier like Pelican. They always take care of me when I need something. Then once you have the car running good look at places like Paragon and Lindsey.
Old 04-22-2011, 06:11 AM
