944/944T throttle position sensor
I was told that a 944/944T has a throttle position sensor that has an integrated idle switch and WOT switch. Does anyone have a part number for such a beast? Or better yet, does anyone have one they would be willing to part with???
Thanks, Brock
Past: Twin-turbo 964 that's backdated to look like a '73 RSR Forthcoming: EV conversion and further weight reduction! Asheville NC |
The NA 944 uses 944 606 113 01 - M14. The turbo 944 uses 951 606 113 00 - M14. I think the NA only uses the idle and WOT positions. The turbo uses these plus the actual throttle position. Pelican sells the NA for $80.25 and the turbo for $121.75.
Thanks!
I'm going to see if the 944 NA version can be adapted onto a 993TT throttle body. I need an idle switch and a WOT switch, and it's a lot easier to mount if it uses the end of the throttle shaft instead of mounting two unique switches at the extremes of the lever travel. -Brock
I bring up this thread again after 5 years
cause if the 951 606 113 00 - M14 is the 0280120400 it has not the WOT switch integrated.I have it here and tested all the way. The only things that i get are: pins 1-2 5V input pins 6-4 idle switch pins 2-3 pot output (variable resistance). |
