sasquatch's Avatar
Hold my beer, I'm going in.
In Feb of this year I did a full front engine seal, water pump, belts, rollers, hoses, coolant, yada yada yada. I guess I did not go far enough. I only did the front seals and did not actually pull the nose cones of the balance shafts. My lower one is puking oil.
The car is up on the rack, belts exposed, flywheel locked, and I am going in. Wish me luck.
Sasquatch
1987 Porsche 944
1974 Porsche 914
"Don't retreat, reload." Sarah Palin
Old 05-11-2011, 11:23 AM
Good luck!!!
Old 05-11-2011, 11:24 AM
sasquatch's Avatar
Crap.
Well, I am done. Seal replacements went really well. Took me about 5 hours.
It's the freaking oil cooler that is leaking. Fired her up and drip, drip, drip, drip.....
AAAAARRRRRGGGHHHHHHHHHHH
Anyone know for sure which oil pressure alignment tool an 87 NA takes?
Sasquatch
1987 Porsche 944
1974 Porsche 914
Old 05-11-2011, 04:31 PM
Porsche Addicted
bnv944's Avatar
i never used any sort of aligner when i resealed my oil cooler. is there one?
*1987 944 n/a. project car.
*1989 mazda B2200 beater <-- Update: sent away to be made into IPODS. RIP huebert
*2001 Jeep wrangler SE - THUMPER
"when the wrench starts to turn, but the bolt does not.
The project will take, longer than thought."
Old 05-12-2011, 05:24 AM
sasquatch's Avatar
I found one at Paragon products. It is on order, I will update this thread next week when I do the cooler.
It looks like I can do it without pulling the headers (MSDS). Hopefully this is true as I do not want that pain in the butt.
I'm running out of things to seal on this motor, this better be it. I want it to cross over 200,000 with dignity at over 100mph, not on a trailer.
Sasquatch
1987 Porsche 944
1974 Porsche 914
Old 05-12-2011, 05:41 AM
Had to unbolt my headers and pull them back to do my cooler, didn't remove them, just moved them for a little more working room
Old 05-12-2011, 05:49 AM
"Dude! You kicked my car.
Rudeboy42's Avatar
It might also be your oil pressure sending unit. They're very delicate and most people end up over tightening them especially when putting the wire contacts back on.
Just yesterday I restarted my car after spending almost two months rebuilding the top end and it was leaking oil like crazy. Luckily I had a spare one that I put in and now it's fine.
Old 05-13-2011, 01:01 PM
sasquatch's Avatar
OP sending unit is dry as a bone.
Sasquatch
1987 Porsche 944
1974 Porsche 914
Old 05-15-2011, 08:43 PM
Rudeboy42's Avatar
Just thought I'd throw it out there considering I just had my second one this week go on me.
Old 05-16-2011, 09:24 PM
sasquatch's Avatar
I appreciate it and I was really hoping it was the sending unit, or one of the crush washers on the bypass valve, etc.
Parts are here and it goes back on the lift today to fix.
I want this car to cross over 200k miles with dignity, at over 100mph, not sitting in the garage bleeding. (sitting at 192k now)
Sasquatch
1987 Porsche 944
1974 Porsche 914
Old 05-17-2011, 06:35 AM
sasquatch's Avatar
Done, and no more leak. Finally I can clean up the garage floor.
Sasquatch
1987 Porsche 944
1974 Porsche 914
Old 05-18-2011, 06:11 PM
