Front Seal keeps popping out!!!
i'm been trying to get my 2.8turbo running for some weeks now.... First time i started it. it ran for a few minutes and oil everywhere The front seal had popped out, it was btw new.. Changed the seal, new timing belt. ran for few minutes and again the seal blows out.... Day three, put in a new oil pump, thou the old one was new also, new seal,,, no leaks, drove the car 1 mile or so, thing pops out... I've changed the oil pressure relive? valve also.... I've been trying to search for some answer, found a few with similar problems but no answer I'm hoping somebody knows something about something ![]() Fannar
Porsche 944 Turbo 2.8 Turbo Porsche 964 Supercharged Porsche 924 Turbo |
I know on cars with alot of crankcase pressure can push seals and gaskets out. Check your PCV system, if it is doing all it can than I wonder if maybe the motor has a bad piston ring?
1983 944 ,1983 V-65 magna catalina22 sold baja ski boat sold my toys |
But, i thougt of this option and did a leakdown test a few minutes ago and everything is okay,,,
Proprietoristicly Refined
Many owners blow out the oil filter seal if the OPRV has not been installed with the alignment tool.
This may be the cause of the front crank seal. Have you checked the "O" rings and alignment on the OPRV? Is the OIL cooler blocked? Did you check the oil cooler for flow restrictions when you rebuilt the engine? GL John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
