Bay Area Patriot
TheStig's Avatar
Unhappy HELP! Squeezing door handle but door won't open!
Help!!!! Last night my car's door handle broke! When the car is unlocked the driver's side doorlock won't open the door! it will only open from the inside. Is there a spring or something that broke on it and can be replaced without buying a new door handle??? or what broke on it?????????????
Andy
1987 928 S4 - 3" Single Exhaust after cats
1999 Mercedes C280 Sport Package
2003 Mercedes ML350
Old 03-02-2002, 02:12 AM
Petie3rd
Mrmerlin's Avatar
Hi go to the dealer and get the plastic piece that goes on the door handle it is white and has 2 ball end sockets on it then remove the door panel and replace this piece you will see it .it is on the door handle mechanisim, now is the time to adjust the linkage and lubricate, also if the door plastic seal is toast go to the dollar store and buy a 1.00 shower curtain and some box tape, reseal the door with the plastic and tape B 4 you put the door panel back on, (this makes the door sound like it is rock solid) and stops air leaks at speed.....Also there is some adjustment in the door handle if you look at the rear of the door jamb when its open you will see a screw this is for attaching the door handle sometimes this screw can be loosened and the handle moved up or down to get the door to open properly without taking the door panel off......Stan
Old 03-02-2002, 08:31 AM
Stan is right on, but first if when you squeeze the handle and it DOES FEEL like something is happening; get a can of WD-40 and put the tube in the handle where the lever is and spray......
Then remove the screw that secures the handle and stick the tube in the hole and spray........ refit the screw.
If the linkage has rusted up or is dirty that will clean it.
This is something you should do frequently; Wurth HHS 2000 is a better lube for the job, but WD-40 will get it working.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 03-02-2002, 10:54 AM
3sonfather's Avatar
Bet it's this cast aluminum peice that broke. I carved a new one and installed it. Sorry I didn't take the photo before I smathered it with lithium grease.
Old 03-02-2002, 01:01 PM
Bay Area Patriot
TheStig's Avatar
Door handle removed and guess what?
The cast aluminum piece broke right at the pivot joint. Its already repaired and I am back on the road...
Just had one hell of a streetrace and getaway tonight...whew but i saw the most *****in' 996 Turbo rip up a Camaro in the quarter
Andy
2003 Mercedes ML350
Old 03-03-2002, 02:14 AM
ch944's Avatar
Not to encourage street racing or anything, but bring your camera and post some pics of the action.
ch944
Old 03-03-2002, 12:23 PM
