WOW!!! Just missed an engine fire!!
Here I am at work (about -15 celcius), I figured I would warm up the car, and check the anti-freeze level (coolant for those of you who live south of the 50th parallel)......
I have the car running just topping of the coolant when I see smoke....... I look at the fuel rail......and there is gas leaking from the 2 injectors closest the front of the engine! I shut it off.... there is gas everywhere..... I can see where it has dried up from who knows how long!! I see gas seeping out from the injector sides, almost like its coming backout from where the injector sits. I had the injectors out in the summer, and I remember there being a rubber ring??? Is this replaceable? or do I need new injectors??? The fuel rail is on tight.....??? Weird???? So here I am waiting for a tow truck...... to tow her home..... ![]() To think about it .....if it was not below -10 celcius for the last week....it probably would have caught on fire......thank God for cold winters......... Any guesses at what would cause this????
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
on my 81 924 the seals are easy to replace just wet the injector with some gas and slide them on
Roger Hall 81 924 N/A Some people are like Slinkies. Not really good for anything, but you still can't help but smile when you see one tumble down the stairs. |
Read everybodies' posts about O rings & caps.
drew1 |
Alex...Since the stars are apparently properly aligned I would buy a lottery ticket....Yes Sir, it is your lucky day...
You may need to replace the o-rings and the injector caps as they get old and crack. Funny that I drove my car for a year with a cracked fuel rail and never noticed it!!
Just a question on this one. Anyone know if you have full coverage on your car and have an engine fire.... does the insurance company cover it?
82 924 restored, 83 944 parting out In search of 1988 or newer nice 944. |
Normally when you get insurance you can get 3rd party liability/ collision/ and comprehensive
Engine fires are covered under comprehensive......
Hmmm think my fuel line is looking weak... ha ha just kidding... seriously
thanks was currious. Why would they not cover a failed belt then?
