Driver
Wheel/lug nut lock, have keys, missing tool.
SO I have the locking lug nuts on my car, but I realized today while working on the car that I do not have the tool that goes in the lug after you get the lock off. This might be problematic next time I need to get the wheels off :-)
Anyone have a picture of what that tool looks like, and/or a source to get it without buying the whole set?
Thanks,
GHEN
'87 944
Old 08-13-2011, 12:04 PM
Banned
There is no tool. Once the locks are off there are standard lugs underneath if these are stock locks.
Old 08-13-2011, 05:07 PM
Driver
Maybe I don't have stock locks, here are some pictures:
They all have little plastic covers that snap over the key holes.
'87 944
Old 08-13-2011, 06:02 PM
SLED GUITARIST
Dan Himan's Avatar
I had to drill mine out. The cover came off exposing a normal lug. Maybe you need to remove the round cover.
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2
1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan
1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD
Old 08-13-2011, 06:27 PM
Porsche Lover
chrisgreber's Avatar
well I know I had some key lug nuts on my old car and I had no key, so I just used a pair of vise grips to get it off. but that's probably just if your not ever gonna use it again.
Old 08-13-2011, 06:33 PM
Driver
I appreciate all of the help, I figured it out. The lock is actually broken on the one wheel I was trying. I sent back out to the garage and all of the other locks pull the round lug cover off after unlocking, just as fwayfarer said.
The lock core is apparently not supposed to come out so now I need to figure out how to get one broken one off.
Thanks everyone for the help.
GHEN
'87 944
Old 08-13-2011, 06:45 PM
Driver
And Dan was right too!
GHEN
'87 944
Old 08-13-2011, 07:04 PM
i will hijack the thread - but not far of the main subject.
inside the lock housing there is a round seal that keeps the lock tight around the lug nut. it is not actually a simple oring but rather flat one. does anybody know if there is a place to buy spare ones? mine disintegrated
___________________
944 Turbo S Guards Red summer DD
944 Turbo S Silver Rose restoration project
Old 08-13-2011, 07:21 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Hook a flat blade screwdriver on the lip at the top of the lug cover (into the groove when the plastic cover snaps) and gently lift the cover up...or grab just the tip of the cover with some pliers...they come off easily. And if you don't mangle the cover, you can reinsert the lock tumbler and continue to use the wheel lock.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 08-13-2011, 09:04 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Yeah, that round sleeve should come right off. A little spray of nut buster lube should free it up if it is stuck. Then tap it with a mallet to shock it and pull it off with needle nose plyers or a small screw driver under the open ring to get it started. I chucked all mine when I changed to Cayman wheels and spent the extra $70 for some really good locks.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 08-14-2011, 06:35 AM
Coming up on your left...
Aufgeladen944's Avatar
Send a message via AIM to Aufgeladen944
I hate locking lug nuts. Keep your car insured. If someone really wants your wheels, they're gonna take them anyways.
I used a hole saw to get mine out like someone on here said. Wrecked the stud, but that thing worked miracles.
1986 Porsche 944 Turbo "S" clone
1998 Honda Accord
Siena College '08
Manager, Mavis Discount Tire
Old 08-14-2011, 01:49 PM
