Intercooler in N/A
Anyone manage to mount an intercooler in an N/A body without swapping to a turbo front end?
If not, are there any good aftermarket options that mount in front of the radiator? Kinda where the AC condenser is supposed to sit.
1975 911S - Twin-plugged 3.5L
www.rasantproducts.com
Old 11-15-2011, 05:37 PM
winter-hater club member
nynor's Avatar
its been done. do a search.
"COOL PRIUS!" - Nobody Ever
Old 11-15-2011, 05:52 PM
Found some good photos and a fellow pelican who has done it. Going to be a PITA but I'm excited to get one step closer to a successful conversion! I really like the NA front end so I'm glad I don't have to swap
Will post pics in my build thread. Also need to show how I got the turbo radiator in there..but that was easy.
Old 11-15-2011, 07:45 PM
I have two front mount intercoolers that I used for my SC project that is no longer. Willing to sell either for cheap, PM me for details.
The second IC worked better for air flow and placement.
Tim
'95 968 (Daily Driver)
'87 944LS (track beast)
Old 11-16-2011, 05:15 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Yes it fits - with a little customization. A 931 vented header panel can be rigged up to feed it pretty well. I've done this on my '85.
Black Cars Matter
Old 11-16-2011, 06:21 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
I have a 931 front panel and an intercooler in my 85.5 NA - It took a little doing because for some strange reason the intercooler doesn't fit. The mounts are there (Strange), and fit the 951 intercooler just perfect. The intercooler tube connections fit perfectly through the radiator support area also. With the nose panel of the NA's that are to flat and will not let the upper front edge of the intercooler clear. So I had to cut the lower front section (Floor of the intercooler area) and fold it down for clearance. I also added extra bracing just in case...The flap that was cut can be folded back and welded back into position at a later date if I wish. A very wide "U" shaped cut in that floor area and the front folded down then all cleared...
Have pfun.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 11-16-2011, 08:34 AM
That's basically what I had to do - trim the sheet metal piece under the intercooler and shave the leading/top edge of the I/C. YMMV - this is on an early car.
Black Cars Matter
Old 11-16-2011, 11:10 AM
Is that lower one from one of the early Reeves Callaway conversions?
I had one for a while - looks very similar.
Black Cars Matter
Old 11-16-2011, 11:11 AM
porscha
matty89's Avatar
on a Na setup would it really make a difference? to be putting an intercooler
porsche 944 1986 NA 8 valves 230k Kilometers on the clock weltmeister chip and coil springs , KYB gr-2 shocks all around , weltmeister throttle cam ! REbuilt head and all new sealed Upper motor ! fresh
Canada , Quebec
Old 11-16-2011, 02:40 PM
nynor's Avatar
i think he is planning on a SC/turbo setup in the future. just sayin.
Old 11-16-2011, 02:44 PM
Nynor, you wise man. Was it the sig that gave it away?? Lol I got the intercooler mounted up! Will post some pics on my build thread tomorrow. Next challenge will be the radiator since the intercooler interferes..
Old 11-16-2011, 07:04 PM
No, that is an aftermarket IC.
Tim
Old 11-17-2011, 03:59 AM
