Send a message via Skype™ to massive
Upgrade single fan to twin fan questions
Have acquired a twin fan to replace the single fan on my 84' 944 (No air-con version). Having just done a bit of further research it seems that the twin fan models also have a twin relay which controls them. Has anyone on here done this conversion before? Was wondering if I can just get away with patching the second fan on the existing single fan lead? If not how do I go about replacing the single relay with the twin relay?
Cheers
Dave
1984 944, 2.5L, manual transmission, UK right hand drive.
http://944foot2thefloor.blogspot.com/
Old 09-01-2011, 01:43 PM
Toofah King Bad
Rasta Monsta's Avatar
Where are you? Wanna sell your single fan setup?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-01-2011, 07:53 PM
Maybe if I find out what I need to do. Located in London.
Old 09-02-2011, 01:57 AM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
Why do you need a twin fan setup? .My car doesn't need one even for Autosolos on hot days, where 1st flatout drives are followed by queuing for the next run.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 09-02-2011, 02:26 AM
Car was getting quite hot when stuck in traffic for prolonged periods even with the fan running. Will be changing the thermostat too.
Old 09-02-2011, 02:58 AM
Toofah King Bad
Pull & flow test the radiator.
Old 09-02-2011, 08:11 AM
How do you do that?
I got my mechanic to empty and flush the whole system when it had a service last week and he said the water that came out didn't look too bad. He was going to do the thermostat but didn't have a pair of long enough right angled circlip pliers to get it out, so had to leave it for now.
Old 09-02-2011, 08:31 AM
Toofah King Bad
Pull the rad and take it to a rad shop. . .
Old 09-02-2011, 09:26 AM
ideola's Avatar
In addition to the recommendations above, you would be better served to convert your single fan set up to a modern, low-draw aftermarket fan (like those available from Davies-Craig). Proper cowling will help with an aftermarket fan...but these units will have superior air flow to the OEM dual fan setup, with the added benefits of being lighter, and imposing less draw on your electrical system.
15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini
Old 09-02-2011, 12:04 PM
I appreciate your suggestions, but I have what I have to work with and that is what I hope to do.
Old 09-02-2011, 01:10 PM
Arizona_928's Avatar
It's a pain in the ass to get the second fan set up. extra relays that go threw the a/c Might be able to get away with building a wiring harness that have two fan connectors. But you might pull too many amps... anyways I don't think that will be a problem.
dolor et pavor
Copyright
Old 09-02-2011, 01:21 PM
