Porscaholic and loving it
So I had to slice out my old pins and the expansion spring thingys went to hell upon the Rust Train, one way trip!
So I just ripped everything out and cleaned up the calipers for painting and rebuilding. But I wanted to know, are those expansion springs 'really' needed? or can I drive just fine without them? For those curious of my reactive behaviour to this situation is I am very low on 'joy spening' at the moment till I get moved to Florida and settled; but I would like to know that I could at least drive (even if I am limping the engine) the thing still and be able to STOP! :P
1984 Maroon PORSCHE 944 (Sold: Nov. 19th, 2011 ![]() 1974 Sky Blue DATSUN 260Z PORSCHE
My anti-drug <3 Last edited by Ez-Bone; 09-10-2011 at 10:54 AM.. |
Misunderstood User
Need em'
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
Toofah King Bad
I wouldn't run without new hardware kits. If they aren't available here, EBS has 'em.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
I have new pins and whatnot but those expanding springs are pricey and I really know I shouldn't be getting heavy priced things at the moment. I was just curious if they are there just to push the pads back when my foot is off the brake so they aren't rubbing (if thats the case then I will get them) or if they are there simply as a noise depression device
My anti-drug <3 |
Toofah King Bad
Pelican Parts - Product Information: 944-351-952-01-M100
Pelican Parts - Product Information: 944-352-952-00-M100 $140 for both axles. . .ouchie. Maybe you should call 944 Ecology and see what George has laying around.
I will try George then.
My anti-drug <3 |
Misunderstood User
You go through labor and time to rebuild your brakes and $35/ wheel is expensive? My time and the inconvience to add these later is worth than $35/wheel. Just sayin'
This is for my benifit anyway so I am not concerned about labor/cost ratios. My concern is that I can get back on the road knowing I have breaks for the time being because I am in a financial crunch at the moment.
My anti-drug <3 |
i'm pretty sure they just stop squealing. If you have pins and one of the retaining springs or split pins to stop them backing out, the pads aren't going anywhere.
It's the movement of the rotor that moves the pads back so the brakes don't drag. Mike
1986 924S, Maraschino Red, Spax adjustable dampers, no air box lid. part way through interior swap. Lots of issues sorted, plenty more to do. 1986 924S, White, donor car, part way through disassembly. |
dkbautosports.com
all the springs do is stop the clunking noise . it will sound the worse when you change direction . like when the car rolls backwards then you go forwards and step on the brakes . it will over time destroy the backing plates on the pads and the caliper were the pads rest . should you replace them yes but you can drive the car for a very short time with out them .
They must be a scrap yard around your area,maybe get a set from them clean them up & you'll be ok for a while.GL
Tags |
brake calipers , caliper hardware , springs |
