Porscaholic and loving it
Ez-Bone's Avatar
Send a message via AIM to Ez-Bone Send a message via MSN to Ez-Bone Send a message via Yahoo to Ez-Bone Send a message via Skype™ to Ez-Bone
Porsche Crest Caliper hardware info
So I had to slice out my old pins and the expansion spring thingys went to hell upon the Rust Train, one way trip!
So I just ripped everything out and cleaned up the calipers for painting and rebuilding. But I wanted to know, are those expansion springs 'really' needed? or can I drive just fine without them?
For those curious of my reactive behaviour to this situation is I am very low on 'joy spening' at the moment till I get moved to Florida and settled; but I would like to know that I could at least drive (even if I am limping the engine) the thing still and be able to STOP! :P
1984 Maroon PORSCHE 944 (Sold: Nov. 19th, 2011 )
1974 Sky Blue DATSUN 260Z
PORSCHE
My anti-drug <3
Old 09-10-2011, 10:52 AM
Misunderstood User
Need em'
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 09-11-2011, 07:23 AM
Toofah King Bad
Rasta Monsta's Avatar
I wouldn't run without new hardware kits. If they aren't available here, EBS has 'em.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-11-2011, 08:06 AM
Ez-Bone's Avatar
Do you have a link to EBS? Google keeps routing me to EBC which only sell pads.
I have new pins and whatnot but those expanding springs are pricey and I really know I shouldn't be getting heavy priced things at the moment.
I was just curious if they are there just to push the pads back when my foot is off the brake so they aren't rubbing (if thats the case then I will get them) or if they are there simply as a noise depression device
PORSCHE
My anti-drug <3
Old 09-12-2011, 09:30 AM
Toofah King Bad
Pelican Parts - Product Information: 944-351-952-01-M100
Pelican Parts - Product Information: 944-352-952-00-M100
$140 for both axles. . .ouchie. Maybe you should call 944 Ecology and see what George has laying around.
Old 09-12-2011, 09:40 AM
Ez-Bone's Avatar
Good grief, thought it would have at least been cheaper for the 924! this makes 944online look cheap lol The part must be super rare or something.
I will try George then.
PORSCHE
My anti-drug <3
Old 09-12-2011, 09:43 AM
Misunderstood User
You go through labor and time to rebuild your brakes and $35/ wheel is expensive? My time and the inconvience to add these later is worth than $35/wheel. Just sayin'
Jim
1983 944n/a
Old 09-12-2011, 09:45 AM
Ez-Bone's Avatar
I have everything else already, just not the expanding springs and not needing to buy an overpriced kit just to get the springs from it. It only took me maybe 3-4hrs total to grind down the calipers, clean, rebuild, and prep for painting. Painting took an additional day adding all the coats and whatnot.
This is for my benifit anyway so I am not concerned about labor/cost ratios. My concern is that I can get back on the road knowing I have breaks for the time being because I am in a financial crunch at the moment.
PORSCHE
My anti-drug <3
Old 09-12-2011, 09:55 AM
i'm pretty sure they just stop squealing. If you have pins and one of the retaining springs or split pins to stop them backing out, the pads aren't going anywhere.
It's the movement of the rotor that moves the pads back so the brakes don't drag.
Mike
1986 924S, Maraschino Red, Spax adjustable dampers, no air box lid. part way through interior swap. Lots of issues sorted, plenty more to do.
1986 924S, White, donor car, part way through disassembly.
Old 09-12-2011, 12:09 PM
dkbautosports.com
962porsche's Avatar
all the springs do is stop the clunking noise . it will sound the worse when you change direction . like when the car rolls backwards then you go forwards and step on the brakes . it will over time destroy the backing plates on the pads and the caliper were the pads rest . should you replace them yes but you can drive the car for a very short time with out them .
Old 09-12-2011, 12:43 PM
ernie9944's Avatar
They must be a scrap yard around your area,maybe get a set from them clean them up & you'll be ok for a while.GL
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 09-12-2011, 05:03 PM
Tags
brake calipers , caliper hardware , springs
