Custom User Title
mikepellegrini's Avatar
Rebuildable Block?
Just tore down my old 951 engine and found scoring on the wall of cylinder 3 (and smaller similar marks in cylinder 2). The long mark is deep enough so you can just catch your fingernail. Can I hone those marks out and use the block without sleeving?
And what is the likely cause?
The engine has about 185K miles. It was running great when I took it out of the car. The only problems were valve guides and the bottom end felt kinda "loose" - like it needed rod bearings (which at 185K is probably a safe guess).
Compression was good -
  1. 120 PSI
  2. 140 PSI
  3. 140 PSI
  4. 125 PSI
And the leakdown test was decent:
  1. 5% loss - intake leak
  2. 20% loss - rings and intake (both) leaks
  3. 11% loss - both rings and intake leaks
  4. 11% loss - rings leak
Whadaya guys think?
I'd like to use this for my son's car.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 09-16-2011, 06:14 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
I would go ahead and hone it out. Most of the very light marks will probably disappear. The larger mark (The gouge/scratch that catches a fingernail) may very well not be worked out, but may not be noticeable under city running conditions. Not being there and accurately gauging the gouge/scratch it's hard to say if the motor will be a perfect runner or not. Under high boost it may be that if the scratch does not hone out, or not hone out enough so that it causes blow-by, so therefore it may never be a perfectly smooth running engine.
Rebuild this one or find a good used block and work on it.
Cause: Almost to many to name them all - Cracked ring, debris introduced through air intake, broken or bad spark plug, hard carbon deposits breaking loose, etc.
Side Note: When a bug hits your windshield at speed, do you know what is the last thing that goes through it's mind ??
It's butt
Have pfun, Ed.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 09-16-2011, 08:37 PM
Custom User Title
Thanks. Would you put new rings on?
16 Ford Expedition
Old 09-17-2011, 07:16 AM
TibetanT's Avatar
If the bottom-end felt "a little loose" when you checked it earlier, then I would do a complete tear down to investigate the crankshaft and rod bearings. IMHO
Personally, I would not put in new rings until I could make a determination as to why the scoring on the cylinder wall appeared in the first place. If this engine has 185K miles on it, and, has not had a lower-end job there is a possibility of having something fail.
Good luck, and...btw, this is just my opinion. I am no expert, just a little concerned for you right now.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 09-17-2011, 11:29 AM
Custom User Title
Thanks.
My son figures to use it in his car. His head is in really good shape, but the block appears to be toasted.
It's gonna be a somewhat critical application so we gotta get it right. His car is modded all to heck:
Lindsey Racing Stage 2 MAF with a piggyback controller
3 Bar FPR
951Max Chips
75# injectors
Lindsey Racing Super 65 Turbo
Open Tial 38mm dual port wastegate
Innovate LC-1 Wideband O2 sensor and digital AFM gauge
Lindsey Racing Manual Boost Controller
Lindsey Racing 3" cat-less, muffler-less exhaust with a resonator
Koni adjustable struts with adjustable ride height with 425# springs and solid strut mounts
Koni adjustable shocks with 550 # Rear Coil-overs (torsion bar delete)
KEP Stage 2 clutch and pressure plate
If I remember correctly, he runs up to around 18 PSI in boost.
His old engine has a problem with No. 3 cylinder:
The compression leak in No. 3 caused oil to back up in his turbo (we think) and destroyed the oil seal in the turbo - when he boosts, it produces a James Bond kinda smoke screen. But the plugs are good, there's no oil in the hard pipes, and the car runs really great.
We figured with nearly a 30% leak to the crankcase, his block must be toast, and that it'd be easier and better to use my old one (after re-doing the bearings).
But if it's gonna be marginal, maybe it'd make more sense to keep looking...
We haven't pulled his engine apart yet, so we're not sure what kinda damage there might be...
16 Ford Expedition
Old 09-17-2011, 02:07 PM
Garage Helper
Well now we know - There is no way a scored block will hold up to all those mods - So go with another good block. Hone the new to you block, rings, bearings and seals, belts and rollers, and a new water pump if not a newish one there already.
Old 09-17-2011, 02:56 PM
if it's a tolerance group 0 or 1, bore it out to remove the scratch
Old 09-19-2011, 07:46 AM
North Coast Cab's Avatar
Hone (by someone who knows how to hone these blocks) and go with aftermarket pistons, or find another starting point. From my experience you can get an entire engine for about $500.
Honeing will run you $400-500 and another $750 for pistons/rings. If you are trying to make big power I would go the hone route.
1985.5 944 GTS
Old 09-19-2011, 10:05 AM
txhokie4life's Avatar
Could it just be the rings on #3 on his engine causing blow by?
Your getting good sealing with the 2 caps of oil.
Not sure if that would or wouldn't occur if you had some block issue.
Either way it looks like you're going to pull that engine out and look at it --
see if there is something obvious with the rings or cylinder wall there.
M
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 09-19-2011, 10:38 AM
Custom User Title
No, my son's car doesn't smoke except when he boosts - and then, it really is intense. The plug looked in good shape - no big carbon deposits. The boost hard pipes and the intercooler are relatively oil free.
But he goes through a tremendous amount of oil - maybe a quart a day!
It's gotta be the oil seal in the turbo.
I found this really great thread on honing by HondaDusteR: Project 924 S engine replacement
He reused his old pistons. I think this may be more in my ballpark.
We have yet to tear down my son's engine. It could be he just has a broken ring or something and that his block would be easier to use than mine.
16 Ford Expedition
Old 09-19-2011, 06:20 PM
Garage Helper
It sounds like your son's Turbocharger is cooked (Internal seals burnt out and coked) rather than the piston rings - possible - Son's motor may be an easy rebuild.
Old 09-20-2011, 09:20 AM
