Knocking noise
What is the sound when I shift the gears in my 944? It just started doing it. As soon as the gear shifts it makes a knocking noise...
Banned
Does your shifter have play in it?
I mean, a little.. But nO more than it did before
rubber centered clutch? CV joints loose? Shock bolts at rear? rear sway bar links/bushings?
Probably something pretty easy...clutch is a job though. |
944 addict
If it's the clutch, replace it with a conventional spring centered clutch plate. The rubber centered ones are junk. Do you see the shifter moving around when you hear the noise?
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
It sounds like it's coming from the transmission. And it started making the noise after I went 155.....
Thread Tools | |
Rate This Thread | |
