SLED GUITARIST
Dan Himan's Avatar
TA Question
My 87 S TA makes a slight clucking noise while sitting in neutral with the clutch not depressed. It does not have a rubber center clutch. The noise is clearly in the rear. Other than that the TA work perfectly and makes no other noises while in use. I read somewhere about it being some bearings. Anybody know which ones in the TA?
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2
1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan
1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD
Old 10-17-2011, 08:34 PM
Proprietoristicly Refined
John_AZ's Avatar
You need to separate the TT torque tube from the TA transaxle to isolate the noise further.
With the car in neutral, clutch not depressed, the TT & TA are still both spinning with the engine rpm.
Slide the rear TA & TT coupler to the rear and then do the test.
If the noise is still there it is the TT (because the clutch is not depressed) if there is no noise it is the TA
Noise in the TA could be normal wear on the shafts and bearings--repair or rebuild cost from $1500 & up.
Bearings in the TT can be replaced.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Last edited by John_AZ; 10-18-2011 at 01:13 PM.. Reason: Thanks to fwayfarer for correcting my TT & TA reply
Old 10-18-2011, 06:32 AM
SLED GUITARIST
Dan Himan's Avatar
Thanks John.
Old 10-18-2011, 08:51 AM
Banned
John you got it backwards. When you disconnect the transmission if the noise remains it is the torque tube. If the noise stops it is the transmission.
Old 10-18-2011, 10:49 AM
John_AZ's Avatar
RIGHT!
My mind was asleep at 6:30am AZ
John
Old 10-18-2011, 01:11 PM
John_AZ's Avatar
More:
If i am wrong and the 944S does not have the inspection plate do not continue.
If it appears the TA is at fault or clucking, on the passenger side there is an inspection plate.
To remove the inspection plate,
A-Drain the TA fluid--Screen it with a white cheese cloth and check for silver flakes
1 Remove the CV joint on the passenger side next to the TA.
2 Remove a bolt inside the TA hub.
3 Slide the hub out (good time to replace a hub seal if needed)
4 Remove about 12 bolts around the inspection plate
5 Pull plate off and inspect the magnet for silver flakes.
6 Check as many gears for damage and unusual movement---
7 Now put it back together because there is not an adjustment that a normal mechanic can do.
GL
John
Old 10-18-2011, 01:22 PM
SLED GUITARIST
Dan Himan's Avatar
BTW I forgot to mention, it only does this when thoroughly warmed up. I will be putting this on my long list of stuff to do.
Old 10-19-2011, 05:53 PM
What about if it is an automatic transmission and the noise occurs in both drive and neutral?
Old 11-05-2012, 06:10 PM
John_AZ's Avatar
Have you changed the fluid and cleaned the filter?
Member RC924 has the knowledge on automatics:
944 auto transmission whinning
Interesting info:
924Board.org :: View topic - Auto tranny hot up thread
GL
John
Old 11-06-2012, 05:27 AM
Upon further listening, the clucking noise seems to be coming up thru the shifter lever opening. My guess is the front bearing in the TT is on the way out. Is there anything else it could be? If it is the TT, is there a way to get grease in to the bearings?
Old 11-06-2012, 10:00 AM
AFM #725
Gawernator's Avatar
If it's the Torque tube, you basically need to do a clutch job, and then replace the bearings.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 11-06-2012, 10:40 AM
