Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Porsche Crest what model, year and Oil Viscosity.
Porsche model specs are slightly different from year to year.
However, front wheel 4 cylinder models are limited. Porsche C30 Specification very Important!!!
https://www.amsoil.com/lit/databulletins/g2808.pdf
Engine Horror! See pics below
Be Blessed, have a great day...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Last edited by guru944; 01-20-2011 at 08:56 AM.. Reason: Discussion of C30 Spec and Why?
Old 01-20-2011, 08:46 AM
Quality
phoenix_iii's Avatar
You started your own thread instead of posting a reply.
The manual states 10W-30, 15W-40 for winter and summer, respectively, for my 951... =)
But everyone else seems to like 15-40[synth] or 20w-50[conventional]...
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 01-20-2011, 08:51 AM
guru944's Avatar
Porsche Crest Engine Horror! Using Wrong Oil in Wrong Temp!
"A Pictures say a thousand words"
See below!
Vehicle owner did not follow Manufactures specs on Oils and Damaged engine with less than 25 miles after change.
Repair is Big $$$.
Guru944
Old 01-20-2011, 09:06 AM
Quality
Roger, after rechecking, 15W-40 would be a decent choice (synthetic), otherwise 20w-50 for conventional...
Apparently Syn and Conventional do behave differently when very cold out 0-30F
Old 01-20-2011, 09:33 AM
sasquatch's Avatar
I highly doubt that it was an oil related failure. There is no main stream oil available to us at any auto parts store that would cause significant damage within 25 miles of changing the oil. Non, nada, nothing, no way, no how.
I have been running out of spec oils for over 100,000 miles in my 944 with no problem at all except a front main oil seal leak. Now, was that because of the oil (Rotella T synthetic, 5w-40, diesel oil) or because I have 190,000 miles and 24 years on the motor?????
Sasquatch
1987 Porsche 944
1974 Porsche 914
"Don't retreat, reload." Sarah Palin
Old 01-20-2011, 04:44 PM
Quality
Maybe a LACK of oil [related failure]! =)
Old 01-20-2011, 05:23 PM
porscha
matty89's Avatar
i use 5/w50 Castrol syntec in my 944 86 and its not dead yet ! i live in 0degree to 30degresss summer time ! so i should be puttin a 10w30 to 50 grade i might switch this summer when i take it out to see if there is a really difference in the smoothness of the motor
porsche 944 1986 NA 8 valves 230k Kilometers on the clock weltmeister chip and coil springs , KYB gr-2 shocks all around , weltmeister throttle cam ! REbuilt head and all new sealed Upper motor ! fresh
Canada , Quebec
Old 01-20-2011, 06:43 PM
ernie9944's Avatar
[QUOTE=guru944;5796693]"A Pictures say a thousand words"
See below!
Repair is Big $$$
Hey! man ,beside starting two oil threads in one week your coming with this BS about some owner not following the Manufactures specs on oil & doing this kind of damage with only 25 miles on his oil change, excuse me to be so blunt but who do you think we are .I've been around cars for a long long time ,from MG TD to 911 to 944 & now a 968 plus a variety of muscle cars & never heard or seen such a thing.Either this guy lost all is oil & kept going or he change it & forgot to put new oil and filter in .Tell you what I'll buy the cheapest oil out there put it in your car & after 25 miles if your motor substain the kind of damage shown you just got a very nice & tip top shape well sorte out low mileage 968 free MINE.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 01-21-2011, 05:09 AM
guru944's Avatar
Sorry brother Ernie9944;
Did not want to offend anyone including You, but also like you I have been seeing a lot of threads on some basic vehicle care.
Here's the story behind the Pics on this post.
A local friends son who is 19 yrs old did'nt put the best quality oil in his 1st gen 944 (~140K) infact it was GTX 20w-50 and started his car 84 944 to go on a date when the temperature dropped 6 weeks ago and left the car running in the yard to warm up. When he came back a few 5 min. later and herd a "clank clank clank noise" finally shutting of the engine after. Car would not restart. A few days later he called me.
His dad(has 924S, 951 and graymarket 944 Euro) is besides himself right now.
Son wants my shop to do a project rebuild and turbo conversion now.
It would be bad if someone else didn't learn from my friends sons "Blunder".
Just wanted to give my fellow Porsche lovers/others a heads up to read the manuals, use good sense and speak to the right sources...
That's all.
Grace and Peace to you and all.
Guru944
Old 01-21-2011, 05:51 PM
sasquatch's Avatar
I would bet large money that the Castrol had nothing to do with the failure. Castrol has been run by many Porsche enthusiasts for years with no problems and I would consider it a very good oil for a conventional. 20/50 is a little thick for the cold temps, but still, unless it was like 30 below zero, the oil still would not have caused the problem.
Sasquatch
1987 Porsche 944
1974 Porsche 914
Old 01-21-2011, 06:10 PM
ernie9944's Avatar
Lol man,it does happen that my 944 was born & raise on conventional Castrol GTX 20w50.And also I did started it up & drove it in in pretty cold .I don't think your friend mishap happen because of the brand of oil use, it probably when nuke for some other reason (what about oil starvation cause by a faulty oil pump?)
Old 01-21-2011, 06:23 PM
Pete R's Avatar
(not taking sides here but..)If I was 19 and just blew up the Porsche(most likely showing off on that date) yeah, that's about the best story to go with, "I was warming it up Dad"
Old 01-21-2011, 06:59 PM
333pg333's Avatar
To use a New York term, Baloney!
Patrick
Youtube 333pg333
86 modified 951
Old 01-22-2011, 03:48 AM
guru944's Avatar
LoL
Grace and Peace to all...
Guru944
Old 01-22-2011, 06:55 AM
Sorry, but I've done many rebuilds on every thing from lawnmowers to p-51 mustangs and the first 2 pixs are not a failure that would occur from the wrong oil at idle speeds.
Old 01-23-2011, 09:04 AM
Architect / Car Guy
carlege's Avatar
Send a message via AIM to carlege
Guru944 you own a Porsche shop and you believe that the wrong viscosity oil did this to an engine?
What is your basis for this assumption?
Looking Forward to getting my First "car" Porsche 951
Old 01-23-2011, 01:12 PM
Pete R's Avatar
I suspect Guru is an Amsoil distributor
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 01-23-2011, 02:19 PM
ernie9944's Avatar
Just love your short & sweet reply ,by the way that's a hell of a good looking 928 you got there I always did prefer the early model.The Ruff (R) look sharp on it & how much HP your getting out of her.
Old 01-24-2011, 08:55 AM
pjs77's Avatar
I'm getting tired of these "oil threads"
Paul - Norwell, MA
1985.5 944 Guards Red N/A
Koni Sports, S2 sway bars
Old 01-24-2011, 11:19 AM
Pete R's Avatar
It has the 85-86 Euro 4.7 2v with headers and freed up exhaust. Never been dyno'd but it should have low 300's for torque and hp. To tell you the truth my 951 feels faster. Maybe it's the way the boost comes on.. I don't know.. and thanks.
Neon SRT4 track car
Old 01-25-2011, 07:43 AM
