good brake pads
im due for brakes on the 944..any suggestions for a good overall street pad for very spirited driving??
93 964 87 944 88 944s sold (gone but not forgotten) |
Stock, OEM or good quality aftermarket should be fine.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
1984 944 N/A Passadena Gold, No Sunroof 1971 Cuda 440-6, 4 Speed, The Last 440-6 Cuda built, Black 1971 Cuda 340, A/T, Rallye Red 1970 Cuda Ragtop, 383, 4 Speed, Triple Black |
+1 unless your going to track it you'll be all set with about anything even with "spirited" street driving. I'd personally stick with the quiet. low dust. stock pad.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
Toofah King Bad
I used PBR Ult Ceramic for a while. Quite dusty, but will make your brakes feel like a race car.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
i've used a LOT of different pads over the years, trying everything from ceramic to semi-metallic, but i've really come to like the Porterfield R4-S for street cars. i use them on everything now. much less dust, and what dust is there is much easier to clean. no "cold stop" issues some other pads have, and they seem to last quite well. most importantly, i don't see the fade i get with OEM pads.
'68 911 / '86 944
My experience with Metal Master pads is poor. Dirty and early rotor warpage. I run Hawk blue now. Expensive and squeek, but they work.
Jurid pads work pretty well and as an added bonus you can be sure they were made back in the day when 944's were hot stuff because the box says "Allied Signal" on them.
I have no doubt your right.
i ran metal masters (starting way back when they were repco) on the mgbs for years and swore by them. then i put them on my e30 325 and discovered the cold stop problems. i also discovered the rotor wear issues. nasty. i've seen the same issues on the 968.
since then i have had the chance to match them up against other pads on the 968. i've looked carefully at all of the concerns, and so far i have not found a street pad better than the Porterfield R4-S. there are definitely pads out there that cost less. there are pads that make a bit less dust, but they trade it off against braking. there are pads that last longer, but again trade off against braking and fade. pick your priority. cost, longevity, dust, or the ability to stop the car? |
