Porsche Lover
Exhaust Fail
i recently went to change my my exhaust manifold gaskets and found this is where my exhaust leak was coming from. haha
well...****
Welcome to my world. Mt stud was broke and i cannot get the 1-4 back on. just got the 2-3 off to try another 1-4 (bigger with bellows) and cannot get it past the block. one thing after another. Going to try to raise the engine next. my 2-3 was cracked too. If you can avoid touching the 1-4 do it!!!!
Current: 1986 944 Turbo. Dual Lindsey WG, lightened Turbo, Guru 18psi (currently running at 14psi), Konis, momo racing wheel, endless fixes, etc 2002 Mercedes S500 (wifes fully optioned baby) 2007 Triumph Tiger 1050 (dependable baby) Past:1983 Black 944 (bought 2008) & 1984 Black 944 (1986 and what got me started) |
Bad Friday afternoon @ the P-factory,did we do that ? not sure we have another Becks and think about it,Ya Ya all good.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
Toofah King Bad
Hmm, another reason for ceramic coatings?
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Porsche Lover
Dog-faced pony soldier
Ceramic coating wouldn't have done squat to prevent that.
Are you (or do you know) a good welder? That's completely fixable.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Basket Case
My Exhaust leak is also quite obvious.
currently waiting for parts. ![]() The good news is, I've got one less stud to remove. The bad news is I have no idea where that stud's gone.
1983 Porsche 944 "The Captain" - Project for 2013 Targa Tasmania |
I do not envy. if your lucky it just worked it's way loose. hit me up I'll send you a spare one.
dolor et pavor Copyright |
Basket Case
Awesome, thanks for the offer.
I've got one stud on it's way from Pelly parts all the way to me here in Australia as part of a larger part order. Cheers anyway.
Fara, you sound just like me before I started getting into it. More than likely the stud is broken if not missing. This is exactly how my continuing 2 weeks repairs started. If you were local I would let you bottow my right handed drill to get it out if you find that (diag mirrors are cheap or use your cell phone video if you have it to check what is in there). Read my thread below and turboducks comments especially. The left handed bit worked great. I am going tommorrow to my friends to life the engine and try to get the new 1-4 in.
Exhasut Manifold bolt missing! Good luck my friend! (and wish me as well)
Basket Case
I'm sure I'll find out the bad news tomorrow morning when I start stripping everything out...
Expect photos and swearing. Going to get a case of cider on the way home.
Fara good luck, hopefully yours will turn out better. I just got back from friends. 1:00 to midnight straigh on Friday, 10-6 today. finally got all the header back in, was a major pain in the ass. The last stud on each set is the hardest.
Started the car up and still felt a leak on #4 Just left after that and will continue tommorrow..
Burn the fire.
Fara, good luck. The top of that gasket is toast.
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
Toofah King Bad
Maybe a little more than squat if it was able to prevent some corrosion.
Basket Case
Well the good news is, I found the gasket!
The bad news is, it appears to be intact, which leads me to believe the stud has snapped off. Managed to get the nuts off the manifold studs ok, but having a hard time getting the nuts off the manifold --> Exhaust flanges. ![]() I'm currently soaking those nuts in WD-40 daily to help un-stick them.
1983 Porsche 944 "The Captain" - Project for 2013 Targa Tasmania Last edited by Fara; 12-18-2011 at 07:52 PM.. |
Basket Case
Deleted. Double post.
Work internet fail.
