AKA_951's Avatar
A/C-Related Fan Operation Question
I've read numerous threads both about the fan relay and fan operations but haven't yet seen the answer to this scenerio.
I have an 87 944, and I have replaced the fan switch and A/C relay (the old one only ran high speed fans and not low). The new (used) relay seems to only run low speed fans. I have only heard the high speeds come on twice in 6 months after replacing the relay, and the temps have reached 100C almost everytime I'm in the city. On the highway, even in the summer, I see temps 85C-90C, so I believe the coolant flow is operating efficiently. My A/C compressor has a slow leak, and once the refrigerant pressure is low enough, the compressor won't turn to avoid damage.
My question is: Does the fact that my A/C system isn't charged fully have anything to do with the malfunction of the fans through the relay. When the key is in the on position, with the A/C button pushed in, should the fans STILL be running despite the fact the compressor won't turn (due to its cutoff switch)?
Johnny
1987 Porsche 944 Turbo
1973 Porsche 914 1.7L
Old 12-30-2011, 09:19 AM
