long block question
does anyone know the answer for this. what is the difference between an n/a block versus turbo block and can i use a turbo block, long block, heads and all, in a n/a 944? i need a motor and found a sweet turbo long block deal and wonder if it will work ok if i dont run a turbo.
Old 01-23-2012, 02:25 PM
9FF 9FF is offline
9FF's Avatar
Pistons are different, you will have to fit your na pistons in the turbo block. The cam may also be different depending on year. There are a few other differences but they won't affect na operation.
Other minor differences might be oil level sender, AOS, flywheel/clutch/housing, coolant elbow, knock sensor. Again just swap out to na stuff from your existing na block, disregard knock & oil level (if your year doesn't have it).
Old 01-23-2012, 02:56 PM
the turbo is a long block, just no accessories, so i can swap my stuff onto it and it will work without changing internals? minus not hooking up what i dont have?
Old 01-23-2012, 03:16 PM
Pete R's Avatar
The turbo has lower compression in anticipation that boost will be added. It will probably work but you may not be happy with the results power wise
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 01-23-2012, 03:34 PM
well, it is an option then i just convert to a turbo and have the big stuff i need already. thanks for all the advise
Old 01-23-2012, 03:47 PM
Toofah King Bad
Rasta Monsta's Avatar
Be aware that 2.5 blocks come in several "tolerance groups," therefore your NA pistons might not be the correct fit for that block if you decide to go that route.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 01-23-2012, 04:01 PM
9FF 9FF is offline
9FF's Avatar
There is some overlap in the tolerance groups plus you can coat the piston skirts to bring them to spec. Plus don't forget those groups were for new engines and not engines with wear like most of ours.
Old 01-23-2012, 04:55 PM
Proprietoristicly Refined
John_AZ's Avatar
Listen to Rasta.
(and the recent post on brakes and sway bars)
FYI and move down on the link:
944 Online Forum - The Porsche 944 Forum For The 944 Enthusiast.
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 01-23-2012, 04:58 PM
i guess i didnt specify but i meant long block, not just block. but someone mentioned compression therefore horsepower loss so maybe i keep looking. i popped a piston thru the old one so a long block or more is what i am looking at now
Old 01-23-2012, 05:11 PM
Toofah King Bad
We were thinking piston swap because a 951 motor without a turbo would be lucky to make 100 HP.
Old 01-23-2012, 05:28 PM
Pete R's Avatar
The turbo's only 8 to 1 comp. I imagine depending on the year a NA would be over 9.5 to 1. I don't know how much of that was done with the head but a lot of it was probably done with the piston. But if the block is good, you could probably get a new/used set of NA pistons and have a nice motor.
Neon SRT4 track car
Old 01-23-2012, 06:27 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Doubt seriously if the block is any good when a piston goes through it -
If you have a good deal on the Turbo Long Block why not go turbo all of the way. There are allot of good used Turbo parts around now days, and being as you are in for a big job any way add all of the turbo and stuff (DME,KLR, Turbo, Exhaust, etc.)
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 01-23-2012, 07:30 PM
Redline Racer
HondaDustR's Avatar
Can't coat pistons that are a larger tolerance group than the bores. Plus, it could get ugly if "worn" bores and pistons aren't measured for taper and out of round to determine that the clearances won't get too tight on the less worn areas of the bores/pistons, esp on a higher heat application such as forced induction. The variances are small, but I would still be careful. No use seizing a motor overlooking details.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 01-24-2012, 07:50 PM
