can 944's run on a test pipe???
I was just wondering if a 1986 944NA can run on a test pipe. I am looking to gain a better sound out of my 944. Is there enough back pressure without a cat. What muffler would you suggest for a nice deep racing sound? What is the H.P. 86 944 put out?
Thank you, Randy
Old 04-12-2002, 08:20 PM
hoff944's Avatar
Send a message via AIM to hoff944
Its LOUD without the cat. I noticed no slack in power when my cat was off.
Old 04-15-2002, 11:46 PM
Makis's Avatar
Porsche Crest
The noise just gets loader but the sound stays the same with the test pipe. To change the sound you will need to change back box to something that makes the sound you like. Removing the CAT should give you better top end power. But it will work better in conjunction with a free flow air filter. You also need to increase the fueling to benefit from the additional air flow. Without this you will be running lean and will not be giving you more power.
Old 04-18-2002, 12:10 AM
What do you mean by changing the black box? Air filter box?
Thank you
Old 04-18-2002, 06:42 AM
Smile
All you need is a resonator installed where the test pipe would go. On my 83 I had the Bursch muffler installed minus the test pipe. In its place is, of course, the resonator. It's that simple.
Old 04-18-2002, 06:47 AM
Makis's Avatar
Porsche Crest
By back box I mean the rear exhaust system which on a 944 is the exhaust pipes silencers after the CAT. This I think is also known in US as the muffler. The exhaust sound is dependent on how muffler is designed. A straight through muffler design will give you the deep sound you want.
Old 04-18-2002, 07:13 AM
Send a message via ICQ to fly944
Thumbs up test pipe
I just installed a bursch test pipe along with a new clutch and like the new sound. As far as mixture my car didn't run any leaner w/o cat. And for power it seems as if there is a slight top end power gain.
Old 04-18-2002, 04:38 PM
Smile
My 83 was way too loud with the test pipe. It also sounded too ricey for me. The resonator works like a charm and definitely lowered the decibels. There was no way on God's green earth I was going to drive my car with just the test pipe.
Stephen
Old 04-18-2002, 06:45 PM
justin's Avatar
Lambic2000,What kind of muffler where you running,I'm curious,I might do the same thing as you did,and I dont want the ricey sound or too loud.
TIA
Texas hosts the 928 Owner’s Club OCIC in 2009
www.928ocicdfw09.com
1980 928 5 speed and a few mods..........
928 OC member
PCA member
Old 04-18-2002, 07:00 PM
WHAGDQG
I AM STILL RUNNING THE OEM MUFFLER WHICH PROBABLY HELPS KEEP MOST OF THE NOISE DOWN. DOESNT SOUND RICEY AT ALL, JUST A LITTLE BIT LOUDER. I CAN'T EVEN TELL A DIFFERENCE WITH THE WINDOWS ROLLED UP.
Old 04-18-2002, 07:03 PM
Smile
I am running Bursch headers and a Bursch muffler. My stock muffler had seen its last day and needed to be replaced.
Stephen
Old 04-19-2002, 06:46 AM
I'm trying to get a Bursch Test pipe for my 944 it has stock everything. i just got it about a year ago and never had any money to get anything put on it. I have a nice job so this summer i'm getting it repainted and hopefully getting a fuel charger and the test pipe.. is this a good idea?
Chris Stoll
'83 944
Old 04-29-2002, 10:49 PM
hoff944's Avatar
the Bursch test pipe has a built in resonator.
Old 04-30-2002, 12:40 AM
Thank you
Old 04-30-2002, 05:33 AM
Smile
I didn't see no "built in" resonator in my Bursch test pipe. It was a hollow pipe. What kind of resonator does a hollow pipe make? My resonator is a glass pack.
Stephen
Old 04-30-2002, 06:46 AM
