Andrew Gawers' Dad
More rim questions
I did the best I could searching here and rennlist, so here goes...
Will the Italy (Italian) made Cup 3 rims with 7.5J x 17 ET23, and 9J x 17 ET15 work on a 1986 944 N/A? Is $200 a fair price for said rims? They come with worn tires, and all four center caps. Here is a link to the add, and some pics he sent me as well. Thanks!! Porsche 911 Wheels 17" Cup3 ![]() ![]() ![]() ![]() ![]()
They are a low enough offset to fit an 86 without spacers, but that's a lot of wheel for an na and heavy too! You will see a drop in performance unless you have some other engine in there. Better choice of tires though than your stock 15s or 16s. Price is reasonable for copies.
^^ Agree that those are heavy for an NA.CHICKS you should look around for some C2-5 spokes 16" lot of them (OEM) available at a very decent price.And they look good on a 944 don't matter which car color.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Go for it.. they will fit.. yes they are heavy..
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
Toofah King Bad
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Non Compos Mentis
One big advantage of 17s over 16s is tire selection.
True high performance tires in 16" sizes are getting slim. Of course, adding unsprung rotating weight will negate quite a bit of the better tire's advantage. |
Andrew Gawers' Dad
How much more do they weigh over the phone dials?
I wasnt looking for rims, these justed poped up. My 944 isn't a daily driver, isn't a race car, just a fun weekend car. I know what the N/A is, I would just want these for looks. Is the difference in weight really going to matter? Will it be THAT noticeable? I'm going to pick em' up tomorrow, can't really go wrong for $200. I'll probably fix the bit of rash on them, paint em' black, and beat on them. Thanks guys! Last edited by CHICKS; 01-31-2012 at 07:45 PM.. |
Yes they are heavier.
Aside from weight, and just to let you know I believe PCA Club Racing Rules ban use of Mille Miglia Porsche repros (such as these) in Club Racing due to structural insufficiency. ^^Not being obnoxious there, just want to let you know. As for numbers on the weights, I don't know. As another aside, I believe this design is claimed to draw air into the brakes. Although I'm skeptical of this because they rotate in opposite directions between drivers and passenger side. Maybe only the brakes on one side get extra air, and the other side gets air drawn out of it? Both by principal bringing in new air either way. Mmmmmm ????? Hope that helps. |
Saying that lots of people do it. I have 17's on my 86na but they are light OZ Racing wheels and I did all the suspension upgrades including fitting 87+ hubs and spindles. Wheel weights: 944racing More Info: ![]()
Non Compos Mentis
While this is correct, I don't think tossing on some 17" wheels on a street 944 is a big deal. I've got 17" Fikses on my 944S with no suspension changes. The car drives wonderfully, and looks a heck of a lot better than with the skinny Phone Dials.
Andrew Gawers' Dad
Picked them up, and put em' on to test fit. The "worn" tires are Toyo Proxes RA-1's. They still look good, and might be good for another DE season. They are heavier than PD, but ya'll already knew that. The steering feels heavy, but they fit and look good. No rubbing when turing, or hitting bumps. I do have Konis on all four corners. They look better in person then in the pics I posted.
Question: The RA-1s had 15psi when I got them but didnt look flat. I'm not going to drive these around town, but what is a safe psi I can run these at just driving around the block? I want to take decent pics of them on the car, just not sure of a safe psi. Will 30+ be ok? Do I treat them like normal tires? Thanks again! ![]() ![]()
Andrew Gawers' Dad
and...Thank you everyone for you help!!!!
Toofah King Bad
32 all the way around and you will likely survive.
Looks good contracts.
Non Compos Mentis
Look good on your car,could you give use the tires size ps.
Andrew Gawers' Dad
Tire size is 235/45ZR17 front, and 255/40ZR17 rear.
Another STUPID questions. Will parking on rocks, like in my pics, 'hurt' the soft tires? Dumb huh'? I could park on some wood, but does it even matter? |
34 psi (cold) will be rigth on for your tires size & wheels,but this is for normal tires.So I'll go with Rasta since he must have experience with RA-1s tires compound.
You will probably have corrected some of the cars understeer with those wide fronts, a good thing, but please check your a-arms are not now sloping up towards the wheels. If they are you will be better of with 225/45's on the front when it's time for new tires. Rears are perfect. They look good.
