Porsche Crest List - Questions - work done to my 944 ;)
Well, I made an actual list of things I do need to start working on the car. For my next order. Feel free to help me get the stuff if you'd like. Just postin up my next order to do to the car.
All new Spark Plugs
Plug wires
Passenger side Window Switch
Passenger Door Handle is very stiff might need a new one? Suggestions on that one?
Rear Hatch Frame?? if possible to find lol
Hood Struts and Hood Arms *Arms that actually hold the hood on*
Driver Side Weather Stripping
Rear Hatch Struts and latches
Hood Upper Latch and Lower?
Starter/Starter rebuild kit?
Suggested Fuel Injectors
Suggested Fuel Rail?
Any Suggested hoses/lines due to original everything.
Rear Wheel Outer Bearings?
Front Wheel Bearings?
Heater doesn't work electrically, Ground bad? or is it a resistor? or? Fan works good.
Well the things I do have questions about now.
Steering coupling loose?
Seat Bolt down Nuts are just turning in place *Just Weld them in place?*
Rear Seat removal for flat carpeting and some customization for a flat trunk all the way to my front seats. I could mount my sub/amp inside it and stuff it nice and well for quality sound.
Would I really need the lower latch for the hood if its a ***** to open? Its not the original Hood or Nose Panel. Would like to Make that work properly. 3 years ago it was wrecked and it dipped under the car infront. Nosepanel/Hood was destroyed. As well as the Popup lights.
All works, Hood latches might be bent? Would you think thats possible? Hood was Wrinkled bad and nose panel was backwards. Lol
Bumper was good,
Work done to it
Replace front engine seals/Including cam seal/balance shaft seals and front crank shaft seal. Replace timing belt and balance shaft belt. Replace H20 Pump and tstat.
Rear Output shaft seal, driver side seat, AC converted over to new style, Distributor Cap and rotor, Flowmaster Muffler, Rear Axle Shaft Boots/Bearings re-packed on both sides. Driver Side Seat reupholstered and re-cushioned.
Clutch master cylinder
Clutch slave cylinder
Clutch Kit
clutch lever bearing
Clutch lever shaft
Pilot bearing
release bearing guide
Crank seal
Shift Lever
DME Relay
Air mass meter ex.
Fuel Filter
Fuel Sending Unit
Radiator
Aux Fan Switch
tstat circlip
tstat shim
orings
Old 03-15-2013, 11:55 PM
AFM #725
Gawernator's Avatar
Fuel injectors, send to Witchhunter or get rebuilt ones, BOSCH. Why do you need a fuel rail, unless your is cracked/leaking? You can probably bring your door handle back to life by spraying white lithium grease inside the door handle, worked wonders for me and helped a few others I told. Your hood doesn't attach? Try calling Parts Heaven or finding a parts car. Do all vacuum lines and all fuel hose. check fuel rail jumper hose. Why do you need new wheel bearings? Inspect, repack and tighten
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 03-16-2013, 12:32 AM
Passenger window switch - swap with a drivers side switch to verify that the switch is bad.
Spray bad switch with contact cleaner are push on it a bunch of times. Most likely it will start working again.
'87 924S 5sp
Slowly recovering from a warped head
Old 03-16-2013, 04:06 PM
New injectors 47$
Witch hunter 28 $+shipping per injector.
Door handle I was thinking that.
Hood doesn't.latch correctly.
Window button I've done that. Its the switch.
Rail replacement. Might have little rust marks. Ill pull off and sand down.
Old 03-16-2013, 04:12 PM
AFM #725
Gawernator's Avatar
How the **** did your fuel rail rust? It's cadmium plated. Take the switch apart and clean the contacts with an eraser inside. Almost guarantee you it will work. Lol I fixed two switches that were "dead"
Old 03-16-2013, 08:41 PM
Oh, Idk. Don't ask me. Probably just Surface rust. I'll wipe it down and clean it up.
I've cleaned the contacts....But i'll try. Its weird cause one side will work when the other is unplugged.?
Wiring issue? Lol
I plan on getting the wiring re-done. Depends though. New Fuse Box/etc.
Old 03-16-2013, 08:43 PM
AFM #725
Gawernator's Avatar
You took it completely apart and cleaned all surfaces heavily with an eraser?
Old 03-16-2013, 09:22 PM
Even better, I used my Dreamal* (Cant spell tnight) lol
cleaned every Connection to a good one, even use my extension to clean where it plugs into. Its as if... I unplug driver side then passenger side works. But when I plug in driver side. Passenger stops working.
Old 03-16-2013, 11:51 PM
ernie9944's Avatar
cleaned every Connection to a good one, even use my extension to clean where it plugs into. Its as if... I unplug driver side then passenger side works.___( But when I plug in driver side. Passenger stops working).
__Lol
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 03-17-2013, 06:29 AM
