Volhv's Avatar
Front Engine Reseal Kit.... Help
Just got the kit from pelican, for my 86 NA, but nothing is labeled.
How would I tell the difference between the cam, and balance sleeve? I have 3 that look the same... shouldn't one be different since they have different part numbers?
As for the 4 o-rings (2 thin and 2 thick), the thin ones go on the front balance seal housing, but what about the thick ones?
Lastly I am a bit concerned about the lack of ridges on the front main seal...
Is this normal, or do I have a defective one?
Thank you,
Old 03-28-2012, 08:10 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Call Pelican about it. They can reference your order and their tech guys will sort it out for you. They're good guys.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 03-28-2012, 04:40 PM
Proprietoristicly Refined
John_AZ's Avatar
Thank you,
The front crank seal is fine.
Here is a picture of mine from Pelican.
Press it in with a short piece of 1 1/2" of PVC pipe + washer and use the front crank bolt to gently press it in until it bottoms. Look at your old seal before you remove it to see where it should end up.
Do not forget the green "O" ring on the shaft---in the order it was removed.
Oil the crankshaft with conventional oil and the inner seal lips.
To help it slide in the engine, I spray the outside of the seal and the engine cavity with WD40--some use Curil-T.
Here is a DIY:
Front Engine Seals
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-28-2012, 05:37 PM
