Hi, Please help me with this. I note that my O2 sensor wire is disconnected, Then I check but I don´t know where is the place to connect this. I already bought and install anew bosch sensor. I supose ! That this place in the firewall is the place. But is damaged then I cut the conection and I will weld this cables. But first I want to know if is the correct place. let me know regards Eduardo |
Euardo,
That looks right to me. You might want to get some heat shrink tubing & put on one of the wires before soldering. Then you can slide it over the solder connection & heat. It holds up better than wrapping with electric tape. drew1 |
Thanks Drew 1 !
