Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
Question O2 sensor connection
Hi,
Please help me with this.
I note that my O2 sensor wire is disconnected, Then I check but I don´t know where is the place to connect this.
I already bought and install anew bosch sensor.
I supose !
That this place in the firewall is the place. But is damaged then I cut the conection and I will weld this cables.
But first I want to know if is the correct place.
let me know
regards
Eduardo
Old 04-30-2002, 01:51 PM
Euardo,
That looks right to me. You might want to get some heat shrink tubing & put on one of the wires before soldering. Then you can slide it over the solder connection & heat. It holds up better than wrapping with electric tape.
drew1
Old 04-30-2002, 05:21 PM
Thanks Drew 1 !
Old 05-01-2002, 03:27 AM
