your average wrencher...
OPRV install after reseal
just did a reseal on my turbo and i used the factory tool. to line up the oil pressure relief valve. it was real tight to pull out and also install the OPRV afterwards.
question is will i have an oil pressure issue now? since it was tight to pull the tool out and install the valve? any tips??
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 04-23-2012, 10:43 AM
Proprietoristicly Refined
John_AZ's Avatar
Here is a DIY for the turbo "Oil Thermostat Housing seal" ----OPRV.
Oil Thermostat Housing Seal Repl
The alignment tool has to come out without binding.
If the tool binds, the OPRV will bind as well.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 04-23-2012, 11:20 AM
awesome thanks John! exactly what i was looking for
1982 931 *project*
Old 04-23-2012, 11:36 AM
okay i pulled it back apart and took another look. i can torque 3 of the bolts down and the tool slides in and out like butter. the last bolt (closest to the OPRV) is whats screwing me. as soon as i tighten it down the tool starts to bind.
is my housing warped? what the hell!?!?! it was fine before i took it apart. help?
1982 931 *project*
Old 04-24-2012, 11:05 AM
Toofah King Bad
Rasta Monsta's Avatar
Tighten "last bolt" first?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 04-24-2012, 10:04 PM
tried rasta.....believe me bro. hmmm......
1982 931 *project*
Old 04-25-2012, 10:06 AM
Figured it out guys. Turns out the new vic. Reinz gasket was slightly imperfect. Got a new one and all went together as planned. No issues so far but then agaon i havent started it yet.
1982 931 *project*
Old 04-28-2012, 07:52 PM
