77 924..clinton twp. mi.
old 924's Avatar
v8 change over(ford)
i've seen all kind's of stuff for GM ..is there a kit for ford.(302 carb'ed)....
.(may the porsche be with you)
Old 05-01-2012, 08:22 PM
BReif61's Avatar
1.) LS engines are far from *****ty
2.) The carb would probably stick out of the hood.
-Brad
2002 Carrera2
1986 944 Turbo
Old 05-02-2012, 05:13 AM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
A 302 is heavy enough to grant you terminal understeer.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 05-02-2012, 05:39 AM
Under the car
Running aluminum heads and moving the battery backward would help. I am not sure I would say "terminal under steer"
Are you suggesting a 302 is significantly heavier than a SBC or LT1?
Old 05-03-2012, 07:57 AM
fiat22turbo's Avatar
The distributor is usually in the wrong place to clear the hood.
Otherwise, you'd have to build your own kit using the same basic principles used in a SBC swap.
Bellhousing + TT adapter + custom motor mounts + custom headers.
Stefan
Portland, OR
1979 Porsche 924 Carrera GTS (clone-ish)
1988 Porsche 944 Turbo S (Silver Rose)
Old 05-03-2012, 08:00 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
With a Cowl Induction type hood will close over the carb and distributor on the Ford motor.
An Alloy LS1 Chevy motor is 30 pounds heaver than a 2,5L 944 motor. A cast iron block motor with aluminum heads, Chevy or Ford is 160 + pounds heaver than a 2.5L 944 Motor - thus to much weight in the front for true balance (and never mind using cast iron heads also).
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 05-03-2012, 01:49 PM
SPD
haroldina's Avatar
Send a message via ICQ to haroldina Send a message via AIM to haroldina
I've been working on an EFI 5.0 install and I can tell you you'll need a pretty short distributor to clear the hood. I'm going with DIS so I can run the throttle body out the front like on an LSx and will be running a box upper intake. I can't see how a carb would fit under the stock hood, either.
The torque tube adapter is pretty simple if you use a bell housing out of a '70 Mustang with a C4 and a slave cylinder from a 2011 Mustang GT500.
You won't find a kit for it anywhere because the LSx is so popular. Most people would argue the LSx is the tool for the job, but I figure it's my car and my money so I'll install the engine I want to use.
1984 944 "Elka" Ford 5.0
Old 05-05-2012, 04:08 PM
old 924's Avatar
amen good for u..i was just thinking out loud when i posted this A. i have a 302 from a 93 cobra just sitting around with under 100,000...and B. all i see is about LS1's..and they are a great motor...just being a ford guy and not seeing anything about a ford swap was just getting on my nerv..and i was thinking carb's just cuz im lazy with the EFI...it would be just a dream at this point for me right now..
Old 05-05-2012, 05:36 PM
