77 924..clinton twp. mi.
v8 change over(ford)
i've seen all kind's of stuff for GM ..is there a kit for ford.(302 carb'ed)....
.(may the porsche be with you) Last edited by old 924; 05-02-2012 at 09:10 AM.. |
1.) LS engines are far from *****ty
2.) The carb would probably stick out of the hood.
-Brad 2002 Carrera2 1986 944 Turbo |
A 302 is heavy enough to grant you terminal understeer.
1986 924S bought new. Now used for AutoX and street. Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway Hyundai Ioniq hybrid daily driver Vindicator Vulcan V8 spyder, street legal sports racing car (300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs |
Under the car
Running aluminum heads and moving the battery backward would help. I am not sure I would say "terminal under steer"
Are you suggesting a 302 is significantly heavier than a SBC or LT1? |
The distributor is usually in the wrong place to clear the hood.
Otherwise, you'd have to build your own kit using the same basic principles used in a SBC swap. Bellhousing + TT adapter + custom motor mounts + custom headers.
Stefan Portland, OR 1979 Porsche 924 Carrera GTS (clone-ish) 1988 Porsche 944 Turbo S (Silver Rose) |
Garage Helper
With a Cowl Induction type hood will close over the carb and distributor on the Ford motor.
An Alloy LS1 Chevy motor is 30 pounds heaver than a 2,5L 944 motor. A cast iron block motor with aluminum heads, Chevy or Ford is 160 + pounds heaver than a 2.5L 944 Motor - thus to much weight in the front for true balance (and never mind using cast iron heads also).
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
SPD
I've been working on an EFI 5.0 install and I can tell you you'll need a pretty short distributor to clear the hood. I'm going with DIS so I can run the throttle body out the front like on an LSx and will be running a box upper intake. I can't see how a carb would fit under the stock hood, either.
The torque tube adapter is pretty simple if you use a bell housing out of a '70 Mustang with a C4 and a slave cylinder from a 2011 Mustang GT500. You won't find a kit for it anywhere because the LSx is so popular. Most people would argue the LSx is the tool for the job, but I figure it's my car and my money so I'll install the engine I want to use.
1984 944 "Elka" Ford 5.0 |
.(may the porsche be with you) |
Thread Tools | |
Rate This Thread | |
