odometer stopped working
What kind of a problem is it to find out why my odometer quit working. Speedometer still works fine but no odometer
Old 05-09-2012, 12:30 PM
Most likely either the gear in the speedo for the odometer has slid down or it is stripped. It is only a plastic gear.
Old 05-09-2012, 01:31 PM
flash968's Avatar
yup - happens all the time. pretty easy to change, and not an expensive part. i just did it in a 968 speedo. $25 and about an hour.
Old 05-09-2012, 03:03 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
odometer failure
If your car is an early one (pre 85 1/2) the gear has usually slipped down the shaft. It can be super-glued back in position. If it's a later unit, the gear has probably crumbled from age. They usually break when the odo reset button is pushed while the car is moving. It should only be pushed while the car is stopped. If it's a later car, you can buy a gear and try to replace it but it's a delicate process and it's pretty easy to screw up the speedo needle. There's a couple of places in California that are advertised in Panorama, one in Palo Alto ( I used them).
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 05-09-2012, 03:08 PM
Send a message via AIM to MPitt
I repaired the gear in my 86. I ordered the part from Odometergears.com. The hardest part I think was getting the cluster out because I didn't have the right size socket to take the steering wheel off. They also have this PDF guide that I used as a reference, but it's not too hard if you have the odo in front of you.
1984 Porsche 944
1986 Porsche 944 Turbo
Old 05-09-2012, 11:19 PM
AFM #725
Gawernator's Avatar
My odometer/trip meter is starting to go bad... although recently it has seemed to be working. I want to replace the gear but I'm scared of breaking the gauge cluster
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 05-10-2012, 12:22 AM
uvachief
uvachief's Avatar
Send a message via Yahoo to uvachief
I've replaced the gear in my 86 multiple times. Still has a ghost in the machine. The odometer works but the trip will get hung up on reset a lot of times. Checked the numbers several times and it all looks fine. Last time, we threw a 968 odometer on it. Been working better ever since. Doesn't perfectly match the view window but only a hair off. Try dc Automotive - 140,000 square feet of Porsche Parts and put a bid of $50 or $75 on one of the instrument cluster gauges like a speedo. You will get the entire cluster.
Sincerely,
uvachief
1986 944 NA Red 5SPD
Old 05-10-2012, 02:53 AM
Great! your car will never loss value again.
Old 05-10-2012, 10:45 AM
Dave
odo not working
Hi Folks - I have just replaced 'that wheel' that causes this problem. Part obtained quickly via Pelican Parts. There is a techno thread on this replacement under 'parts/guages/odo wheels'. Just ensure that you count the inner number of cogs that fits your mph/kph speedo. The larger outer cog number is always 20 ie: a 20/23 type unit suits an S2 kph.
Dave
944S2 Cape Town - South Africa
Old 05-11-2012, 06:59 AM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
This is an oft repeated wive's tale, while it does seem to happen often it is usually because the gear is ready to break anyway. With a good gear you can reset the odometer while the car is in motion....I do it all the time and have for years.
The problem is that the plastic material that is used for the odometer gear with age becomes extremely soft and it will crumble...when it gets to that stage, it will break whether the car is in motion or not.
The correct gear for odo repair is available right here from Pelican Parts, and it is really a simple and pretty straight forward process...though care is required when removing the speedometer needle...DO NOT attempt to pry it up or you can break the shaft the needle is attached to. Grasp the round base of the needle and gently pull straight up, it is firmly attached but it will come off.
Sending it to North Hollywood Speedo or Palo Alto Speedo is an alternative, but it's going to cost in the neighborhood of $150 to get it repaired, plus the down time for round-trip shipping and repair.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 05-11-2012, 09:10 AM
Question Recomendation for speedo fix shop in O.C. CA?
My odometer also quit working and I think I'll go the route of getting it fixed. I've heard of a place in Orange County, CA that repairs these. Can anyone recommend a shop?
I plan on selling my 1989 - 944 in very very good shape with relatively low miles (~ 112,000 ) and want to get the odo fixed first.
Thanks,
Scott
Old 05-16-2012, 11:34 PM
89-944NA's Avatar
Thanks,
Scott
North Hollywood Speedo...going to cost about $150.00 to repair, not counting shipping.
Semper Fi
Old 05-17-2012, 01:07 AM
Thumbs up Gails Speedometer fixed it for me
Hi 89-944NA,
Thanks for the tip!
I did find out about Gails Speedometer in Costa Mesa though.
They did all the work for $186.55
187 E 16th St
Costa Mesa, CA 92627
(949) 646-9120
Mike is the owner and is great to deal with - honest as the day is long.
My wife picked my car up and drove it home while I was at work. She asked "Honey are you sure you want to sell this car?" With a new to my family - family car and my motorcycle, I really don't drive the 944 that much and have decided to let it go and let someone else enjoy it. Will be putting it up for sale in Autotrader maybe next week or so and will also post here as well.
Thanks again for the tip 89-944NA even though I did not go with them (it is the thought that counts, right).
Best regards,
Scott
Old 05-23-2012, 12:19 AM
