alan6272's Avatar
2.5L twin cam??
I am not very familiar with the 2.5 twin cam, is it a good motor? I seem to read that it is not? Thanx, The car I am looking at tomorrow has this.
1983 944 ,1983 V-65 magna
catalina22 sold
baja ski boat sold
my toys
Old 06-06-2012, 06:02 PM
As far as I am concerned Porsche never made a twim cam. Toyota made a very reliable unit.
It maybe a 16 valve model from a 944S
1983 Porsche 944 2.5Ltr
2004 Holden Monaro 5.7 Litre
1976 Triumph Dolomite Sprint 2L 16V
1999 Daewoo Lanos (everyday car) 1.5L
Old 06-06-2012, 06:39 PM
The 16 valve is a DOHC motor. I'll let someone who owns one chime in on whether it's good or not
1988 944 N/A Depowered Rack, 968 Swap "In Progress"
Old 06-06-2012, 06:43 PM
sorry you are right, it is a DOHC. Sorry brain fade...
Old 06-06-2012, 09:09 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
If it's a 2.5L DOHC, it's a 944S, a good engine, but it does have the additional cam chain pad to consider (they wear and do chip with age) if it breaks it's costly.
Also a bit more complicated when it comes time to change the cam and balance shaft belts, same goes for the 3.0L DOHC 944S2. Suggest you read the procedure located at; Clark's Garage Home Page Look to the last listing in the "camshaft" section.
But they are good reliable engines, just a bit more complicated as noted above.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 06-06-2012, 09:19 PM
alan6272's Avatar
Thank you and it is the 944S he has papers from a dealer who changed the cam chain and tensioner. I will look at it tonite.
catalina22 sold
baja ski boat sold
my toys
Old 06-07-2012, 04:16 AM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
The 16v 2.5L is a good little motor, I had one I swapped into an 8v car.
Tensioner is the biggie, gotta keep an eye on that.
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 06-07-2012, 09:47 AM
968 GUY's Avatar
Learn something new every day.
Thought all dohc 944 engines were 3L.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 06-07-2012, 12:08 PM
I owned an S2 which is a bored and stroked M44/40 (2.5L 16v) with a different intake.
Keep in mind that there are 8 more valves, 8 more valve guides, 8 more lifters, 16 more valve springs, 2 more knock sensors, one more cam, a chain, and a tensioner. The timing belt costs 3 times as much as the 8v belt.
You need to use premium gas with it or it will retard timing to the point of 8v power.
On the bright side there are no speed and refrence sensors jammed in the back of the engine compartment.
I really enjoyed the light handiling and simplicity of my 84 and the power was nice on my S2. I think an "S" would be the perfect blend of the two. Put some good pads and tires on it an then some Koni shocks and you would have a really fun car.
Jackson
Old 06-07-2012, 04:13 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Thumbs up Fun car to drive and Own...Rarely seen
Best 944 to drive/ Autocross and a sleeper...
Quick if you run 93 Sunoco Ultra.
No regrets....
Later
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 06-07-2012, 07:46 PM
89-944NA's Avatar
Nope, the 944S is a 2.5L.....3.0L weren't made until model year 1989.
Semper Fi
Old 06-08-2012, 12:23 AM
alan6272's Avatar
sold before I got there oh well
catalina22 sold
baja ski boat sold
my toys
Old 06-08-2012, 04:19 AM
Jackson
On the S there is a single speed/ref sensor on the back of the engine, and there is a horrible intake manifold in the way of getting to it.
Old 06-10-2012, 10:30 AM
