Hi guys,
My son has been a long time Porsche lover and now that he has turned 21 and he has matured, I am looking to get him his first baby to take care of. The car I have found is a 1982 Porsche 924 T-Bar Automatic and the deal looks too good to be true, which is why I am a bit cautious. The car has recently had the interior restored as well as the exterior paint resprayed which is why I am slightly concerned that there may have been an accident in its history which I will investigate tomorrow when I see it. It has full log history which also shows that it was garaged from 1995-2005. The odometer shows 95,000kms but I think its more likely 195,000 due to their only being 5 digits on the dial. What are some common problems that occur with the 924 that I should look out for? Or what should I check when I see it tomorrow to be sure that I am not buying a lemon? The asking price is $4,000 and I want to make sure its not going to die as soon as I drive it out of the driveway. Any help or suggestions would be amazing and very much appreciated. Shannon ![]() |
Welcome to the board
First off ,where are you located? normally 4k is way too much for a 924 but depends from what part of the world are you. In US 4k is 944 territory . I suggest you go to 924Board.org :: Index ,best place to get all the info you need on 924's
Catalin '86 DD |
77 924..clinton twp. mi.
the early one's are not known for their auto"s stick with a 5speed...go to 924board.org..that's where you'll find mostly the 2.0 924's..77 to 82 here in the U.S..
.(may the porsche be with you) Last edited by old 924; 06-06-2012 at 11:28 PM.. |
AFM #725
If it's an automatic, that automatically decreases its value quite a bit. Less desirable.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
There probably isn't a huge choice of those cars in Australia. Probably Australian cars had the full 125 bhp so peformance even with the 3 speed auto won't be too bad but even with a 5 speed manual they weren't exactly fast. The rubber damper for the auto trans. is expensive compared to a clutch, and labour intensive to replace, but not more so than for a clutch.
A friend in UK bought an 83,000 mile 924Auto in good running order last year for under £1000 incidentally. A couple of parts in the cold start circuitry were replaced with bits from eBay to ensure good starting.
1986 924S bought new. Now used for AutoX and street. Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway Hyundai Ioniq hybrid daily driver Vindicator Vulcan V8 spyder, street legal sports racing car (300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs |
Proprietoristicly Refined
If you decide what car is best for him, he may resent the choice. John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Nooooooooooooooooooo!!!!!
1988 944 turbo |
it is a good car with less to go wrong and a lot less up keep then the 2.5...but it is much slower (ask me how i know) but very fun to drive..
.(may the porsche be with you) |
Tags |
1982 , 924 , buy , help me , problems |
