fuse panel help
i need help trying to identify what wires go the the connectors on the back of the fuse panel. I just completed a re-wiring and need help. I haven't been able to find anything that shows the wire colors to the 17 connectors. I have attached a photo. If someone can offer some assistance it would be greatly appreciated.
Old 06-10-2012, 05:07 PM
How about a picture? Anyone out there that could post a picture of their fuse panel for reference. My car is an early 1985 944 and I really want to get it back on the road....
Old 06-12-2012, 04:23 AM
Custom User Title
mikepellegrini's Avatar
I'm looking at the picture you posted and don't recognize anything. Where is this? On the back of the primary fuse/relay panel?
The factory wiring diagrams show the wire colors.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 06-12-2012, 06:57 AM
yes, this is on the back side of the primary fuse panel up under the dash. I'm having a hard time figuring out the color of the wires that connect to the connectors. I have looked at the wiring diagrams but can't tell what wire goes to the connection.
Old 06-12-2012, 09:48 AM
Back from Beyond
IIRC those are the G and H connectors, and the wiring diagram in the Haynes does tell you which wires go where (even though they've got some errors). Follow the lines on the tops of the pages (they indicate the connections within the fuse block) and when you find a G, note the color attached to it. The spades on the back of the block are numbered, so tinker-toying it back together is really Tab A, Slot B. Have you had a look at the wiring diagrams here on Pelican?
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 06-12-2012, 09:57 AM
Back from Beyond
http://www.pelicanparts.com/944/electrical/944_84_1_1.jpg
In the above you'll see two wires connected to terminals marked 'H'. They're red, and their gauge is also given. So find the two big red wires and connect them to H on the fuse block. And so on...
All others GONE!
Old 06-12-2012, 10:03 AM
Proprietoristicly Refined
John_AZ's Avatar
mhanrahan
I tried to get a picture but my wiring is so tight and snug I could barely move the fuse/relay panel off the mount.
You will need to get help from a dismantled car or go to a wrecking yard and hope someone pulled a dash.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Back from Beyond
Behold the evil blue plug...
All others GONE!
Old 06-12-2012, 10:06 AM
I'm heading home to see what I can find. It's nice to have a forum like this to get help. Thanks I'll keep you posted
Old 06-12-2012, 01:16 PM
ok I have been through the wiring diagrams and have attempted to follow the wires. I understand the wires going to the fuses. I can not tell what wires go to the spades that are numbered 1 through 7. I know the three red wires connect to the spades between 6 and 5. spade 4 has a green wire and a white wire in the front, spade 3 has a black and yellow in the front and white in the back. spade 2 in the back is purple and spade one in the back has two yellow and white wires. Thats what I have that I think is correct. I cant find any of those wires in that combination on the diagrams. If someone out there has any recommendations or can offer any help it will be greatly appreciated.
Old 06-12-2012, 06:47 PM
