Blinker Issue
So I am having a blinker issue which is important because I can't get the car street legal until it is fixed.
1983 944 N/A All of the blinkers work properly and blink properly except for the front left. This blinker blinks bright which the headlights on but when they are not it blinks but so low to where you can't see it. It is only this blinker so I know it is not the fuse. I replaced the bulb and that is not it. If you have any guidance for me that would be awesome. Mahalo from Hawaii! |
Location: In a dumpster behind Albertson's in Los Angeles County
Check and clean the ground for that light
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
Ill check the ground and let you know.
winter-hater club member
new blinker fluid?
just kidding! i would check the ground but also the wiring at the blinker. pull the whole assembly out and see if someone has been splicing stuff or if there are breaks in the insulation, etc.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
sanded the ground and reconnected them in a different order just to see if any effect, and none once so ever. So now I am in the situation of assuming its wire corrosion, need some advice on how to rewire this, or advice on another possible fix. It blinks dim but all the other blinkers work so I am assuming it is not a fuse or wire relay issue. Don't all the wire relays and fuses go to ALL the blinkers? Need advice ASAP!
does it still come on bright with the headlights on?
what about with the headlight buckets up, but the headlights off?
my motor is broken so I always leave them up, and maybe I was wrong before but they blink dim no matter what. Unless it is the hazard light. When you turn on the hazards it blinks correct brightness. I would love to get this problem fixed tonight to get it inspected tomorrow!
well, it isn't wire corrosion.
replace ALL your fuses. pull the signal switch assembly and clean ALL the contacts. if you still don't have joy, work your way backwards: connect the power source directly to the positive terminal for the blinker. if it works, keep moving backwards until you find where the connection gets hinky.
still nothing.
it's been awhile since i pulled that switch on my '83. sorry. i do remember it was a PITA. you are gonna have to sort it out.
as for cleaning, get some electrical contact cleaner from radio shack.
