adrial's Avatar
Send a message via ICQ to adrial Send a message via AIM to adrial
first REAL car problem...bad bucking!
Today, I drove to a little local car meet...parked...drove for 30 secs (probably spent more time idling than driving)..parked for an hour...drove home. About 5 mins into the drive home...it started bucking very badly.
At first, it was only if I brought it up to a certain throttle position (which yielded less than 1 bar on the gauge..atmospheric pressure..call this situation #1)...then it just wouldn't go anywhere period for like 10-15 seconds...After that it went back to the way it was before that (bucking at above a certain throttle position). The only time I tried WOT was when it was doing situation #1...car didn't go anywhere...but it did hold 1 bar on the gauge...
Thankfully I got home and parked her in the garage...
I am thinking TPS, someone else suggests fuel pressure regulator? Any thoughts? I already have a TPS on order from paragon, but if I really need it I can get it quicker from my mech (they order it, its there the next day).
I don't wanna drive the car anymore out of fear of getting stuck somewhere...
Also, I noticed that my vac leak was much more of a sharper hissing sound when I started it up tonight...meaning I guess faster air flow (bigger leak). The hissing is coming from the AFM area (or it was, I haven't checked again yet)...but the AFM is solid, carb cleaner did nothing. So I and 2 mechs determined it was normal. However, if I disable the idle stabilizer, the idle drops to 400rpm...the idle screw can't raise it but can lower it further.
Help me!
thanks,
Adrial
'89 951
Alpine White, Black Leather
Old 05-23-2002, 10:00 PM
adrial's Avatar
It was the fuel filter.
'89 951
Old 05-24-2002, 10:27 PM
