Progressively runs poorer until won't start
I just completed a top end rebuild on my 944s 16V 1987.
It had been on blocks for six months, since the belt blew, and I twisted my valves like a cheap group of pole dancers...interesting, but nut upside. Nonetheless, i had the head done, and all was good.
Also, while getting things together, I had the cams done by Web-cams.
When we started it, the motor ran smooth, however, the top end wasn't getting oil. After replacing the one way check valve on the head, all was good.
I drove it around the block, and it ran very well. Then, two blocks later it felt like I was on 3 cylinders. I got back to the house, went around the block a few more times, and parked it. I was able to start the motor a few more times, each time the motor was harder to start. Now it won;t start at all.
A couple of items:
1) new plugs, cap and rotor
2) I cleared the fuel tank, cleaned the strainer, back-flushed the newish filter, and bench-checked the fuel pump.
3) New Master Blaster 2 MSD coil
Any suggestions on what to look for?
LC
Old 08-30-2012, 12:27 PM
txhokie4life's Avatar
Weak battery?
loose vacuum line or leak?
m
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 08-30-2012, 01:30 PM
I would check that the rotor screw is still tight.
Old 08-30-2012, 02:00 PM
968 GUY's Avatar
After checking the rotor,I would check the sensors.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 08-31-2012, 05:51 AM
