Railroadmike's Avatar
Clicking when shifting
OK 1989 944 N/A. When you are Stopped and you return the shifter from a Gear to the neutral position and you release the clutch petal, there is a nice stroke clicking noise. Almost a pop? Also sometimes when I first start driving the clutch petal tends to stick to the firewall? Once the car is running a few moments, the petal sticking problem stops?
Little more info, the previous owner has recently replaced the Clutch cylinder and Master cylinder and claims he bought a Tool to assist in bleeding the system?
When Shifting from 2nd to third, i have a slight grind.... Very mild.
Any ideas?
Old 10-11-2012, 04:12 AM
9FF 9FF is offline
9FF's Avatar
Pedal sticking in down position normally means there is still some air in the clutch line or pedal spring needs adjusting.
When the master/slave was replaced was the line between them also changed. If its an old line it could be the source of a slow leak. Pedal spring can stick if not adjusted correctly or if there is air in the system.
Old 10-11-2012, 04:25 AM
Norm101469's Avatar
Anyone want to chime in on the first part of the question regarding the clicking because mine does that too.
1984 Porsche 944
1999 Porsche 911 Carrera Cabriolet C2
Norm
Old 10-11-2012, 03:13 PM
