Eddie Brown's Avatar
Tire size help
Hello. I was hoping to get some ideas of what size rubber to get for my wheels.
My car is a 85.5
The wheels are Kenisis
Front 8J x 17 ET 47
Rear 9.5J x17 ET 52
For now my car isn't lowered, but if I do it will just be some 1.5" springs.
I've been looking on tirerack, but don't quite know what would work.
I'm looking by price, and plan on spending between 475 - 600 bucks.
Right now I'm riding on repro Turbo twists.
Front 7J x 17 ( don't know the ET ) 225-45-17
Rear 9J x 17 ( don't know the ET ) 245-40-17
I hope this gives you an idea.
Thanks!
1996 BMW 740il
Auto Tech for German Dreams (Bakersfield, Ca)
Old 10-22-2012, 08:44 PM
Let me add a couple of pics...
1996 BMW 740il
Old 10-22-2012, 09:04 PM
AFM #725
Gawernator's Avatar
Tire size calculator
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 10-22-2012, 09:23 PM
Non Compos Mentis
245s in front and 275s in the rear are probably what you're looking for.
I'm using Michelin Pilot Sports, and they are wonderfully sticky, wet or dry. Probably can't get them within your projected budget.
Old 10-22-2012, 09:24 PM
AFM #725
Gawernator's Avatar
+1 on those tires, they were nice on my first 944.
Old 10-22-2012, 09:25 PM
what series should I look for? 40's, 45's, 50's?
I have Michelin Pilots on my e38. Rides like a dream.
1996 BMW 740il
Old 10-22-2012, 09:42 PM
225-45-17 front 255-40-17 rear is very close to original tire diameter.
Clifton
Old 10-23-2012, 06:07 PM
Clifton
10/4 mate. Will look into that.
1996 BMW 740il
Old 10-24-2012, 11:29 AM
You're gonna need spacers with that first set of wheels, 85.5 is early offset.... good luck Joe.
Old 10-24-2012, 02:37 PM
Catamax944's Avatar
225 45 17 and 255 40 17 is ideal for the car and the right diameter for your speedo
This tire size calculator is more detailed http://www.1010tires.com/tiresizecalculator.asp?err=98&rsn=usr-snt-emty-str
ps:your base is 195 65 15 , that is the original 944 tire size and not 215 60 15 that was added later as an option and is off by a minimum of 0.7% .
With 195 65 15 and 255 40 17 my speedo is dead on with the gps up to 120mph.
Catalin
'86 DD
Old 10-24-2012, 03:04 PM
The fronts don't seem to have issues. The rears are kinda close to the spring plate bolts and a seam in the fender well. it could use an extra 10mm. But we'll see.
1996 BMW 740il
Old 10-24-2012, 08:20 PM
joe, if i were to put these on an early turbo car would these fit easier?
1996 BMW 740il
Old 10-26-2012, 08:21 PM
86 turbo is still early offset, any 87 and later 944 have the same offset as those wheels. if you're not tracking the car you can run spacers with longer wheel studs of course! Sorry for the delay
Old 10-29-2012, 03:46 PM
