alutto944's Avatar
Idle Control Valve location???
where is the icv located on my 1986 944 n/a??? can some one please help me pics would be a huge help or maybe aa write up article
Old 11-18-2012, 09:48 AM
Toran's Avatar
Here she is in the yellow
circle
86 944na Alive and Rollin
Old 11-18-2012, 10:04 AM
alutto944's Avatar
gotta take the intake manifold off ....some one shoot me please
Old 11-18-2012, 10:14 AM
Toran's Avatar
Yep, even my long piano fingers couldn't get to it with the manifold on.
Just take your time and it will be fine.
Might be a good idea to have a few manifold gaskets on hand just in case.
Old 11-18-2012, 10:17 AM
Proprietoristicly Refined
John_AZ's Avatar
Nice picture Toran.
You have to do a few WYAIT (while you are in there) repairs.
New AOS seals
New dip stick "O" ring
Should do new hoses front and rear of the ICV and new clamps
New Injector seal kits a must.
Clean the ICV valve-inside carefully
New intake gaskets-4
Replace all Oetiker OEM clamps with new or good substitute.
New vacuum hoses and "T"s.
Check hoses to the intake "J" tube.
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 11-18-2012, 11:26 AM
Toran's Avatar
Well said John!
Keep her on the road
Old 11-18-2012, 11:28 AM
AFM #725
Gawernator's Avatar
That's a little intimidating.. then again I guess it's hundreds of times easier than a clutch job
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 11-18-2012, 12:00 PM
Toran's Avatar
I'm not a wrencher either but I did it.
It doesn't require any fancy tools, just pace yourself and have plenty of time.
Take a few pictures of how stuff looks before removing it so you can reference later.
Old 11-18-2012, 12:03 PM
AFM #725
Gawernator's Avatar
I'd like to say I'm a wrencher! Just novice... speaking of which, time to go replace the 26 year old O2 sensor!
Old 11-18-2012, 12:05 PM
Toran's Avatar
Well thanks to this site I am more of a wrencher!
944 owner for twenty years and it hasn't been in the shop for over 15yrs case I learned a thing or two
Old 11-18-2012, 12:08 PM
AFM #725
Gawernator's Avatar
Funny how things work. Few months ago I was scared to do this job. Now I'm yawning. lol.
Old 02-21-2013, 01:35 AM
Toran's Avatar
Soon you'll have to change "Worst Mechanic You Know" to something else
Old 02-21-2013, 04:15 AM
Catamax944's Avatar
It can be removed without taking the intake manifold off but it's much easier and faster to remove the intake, found that out the hard way.
I've had bad luck with the ICV ,cleaned it the first time and it lasted only 1 year and after that replaced it 3 times ,the second time being with a new one that turned out to be faulty off the shelf. Took my intake manifold off maybe 10 times now for various jobs and went through a set of bolts.
The while your in there jobs are a must if you want to avoid removing it so many times.
Catalin
'86 DD
Old 02-21-2013, 04:50 AM
