alutto944's Avatar
Idle problem after throttle rebuild
i re-built my throttle body and now my car idles at 1000rpm ...how can i get the idle to about 850 like it was before....i already set the idle screw all the way down...no luck
Old 12-01-2012, 03:11 PM
Chunkerz's Avatar
Is the throttle plate closing all the way?
Old 12-01-2012, 03:23 PM
alutto944's Avatar
yes its closed
Old 12-01-2012, 03:28 PM
Dave Colangelo's Avatar
If I am not mistaken there is an allen head screw that you can access from the top of the housing, its on the side some where, I believe it controls the amount of air that flows though the small channel that goes around the valve. Try adjusting it and see what happens. Also make sure that if you removed the valve during the rebuild, when you put it back in it is seating correctly. I have had throttle issues because the valve is not seating correctly (in other words make sure that when it is closed all the way it is actually closed).
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 12-01-2012, 03:55 PM
Hello, Did you follow the instructions on how to set the idle? Check link below.
Idle Speed Adjustment
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 12-01-2012, 05:47 PM
