Motor Head
Turn signals fixed
I had two issues with my turn signals. The first was that they had not been canceling out on left turns. The second, was that recently they started "fluttering" and not flashing consistently at all. I pulled the switch assembly off (after removing the wheel etc) and peeked inside through one of the openings. I could see that the switch makes it's contacts for the turn signals through spring loaded copper colored bars. To improve the contact, I reached inside with one of my small hook tools (used for pulling small dashboard parts like knobs/etc) and bent the copper bar towards the contact. Plugged it in and it was making good contact now. Sprayed a bit of electrical contact cleaner and then some electrical contact lubricant onto both bars (one bar is left turn, one is right). There, nice and smooth. Now for the cancel... I simply heated the tab with a heat gun and bent it out slightly. That's it! Turn signals cancel as they should and nice and smooth! I tried to take pictures but only had my cell phone with me at the time and it wouldn't focus on the small parts I was fixing inside the housing. Maybe I can post a video of it or something if people really need something like that.
2013 Ford Focus SE - 5spd mtx, Spectre filter, Unleashed E85 Tune, much more to come. - DD
2011 Ford Flex - Catless Downpipes, lightweight Mustang Motorsport 20x8.5 wheels, 3 bar MAP, Unleashed 15 psi tune - SOLD
1986 944 Turbo - 100K mile cream puff - FOR SALE
Old 12-01-2012, 01:32 PM
DIY items are always welcomed by the forum and pictures are an added plus.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 12-01-2012, 05:51 PM
AFM #725
Gawernator's Avatar
Turn signal cancels are on my to do list. I also have a heat gun. Thanks for the tip!
Old 12-01-2012, 06:16 PM
Motor Head
Yeah I just wanted to do it a different way than the other threads I found suggesting tape. Just didn't sound permanent enough to me.
Just one thing to do over and that's put the steering wheel back to center. I got a tooth or two off. Oops! One of my pet peeves to have the wheels off center. Super easy to correct though.
Old 12-03-2012, 07:26 AM
