![]() Quote:
dkbautosports.com
i can only state about the ones i have seen . like in my F1000 CAR using a gsx-r 1000 motor or like in the motorcyecles i used to race like the R1 , gsx-r , then all the ones that when i was younger helping out in my brothers motorcycle dealer like the ZX and so on . then when i started racing in the GNCC 1st with husky the for KTM they too all had straight cut gears in the gear box . so do all motorcycles have them well no a hand full don't just like the all don't have them in all sequential gear boxes . but again most do ! then again you really should not include a motorcycle that still uses air to cool it's cylinder heads and has no fuel injection . i would think at some point just bringing the heads up to date with some water jackets around the heads may take the out dated early 1970 design into the 2000's . but you really still can't count a motor that they had to give to porsche to work out the bugs in the cylender heads . the jokes when i was at porsche AG about that were to funny . because i'm no gear box expert and never clam to be one ! i can only tell you what i was told right from my friend tommy at quaife and that is the whine your hearing is coming from the gears in the gear box they are making that noise from the way they are meshing together don't worry about it the gear box is fine . i would have to say it is because it has done 3 24 hour event and still is holding up good along with the one in my sports racer that is 6 years old now and too shifts just fine . i did race a car in a vintage event with a car that had a M22 rock crusher in it this was some years ago and it was not sequential and you needed a clutch to shift . i don't think it had straight cut gears but the noise coming from the trans was bad . on my out lap i called into the pits to ask about it . the reply was it's fine run it ! i was told that it's called a rockcrusher because that what it sounds like when you shift it . i do not own a transmission shop i own a race car chassis ,fabrication shop a high end body shop for ferrari's lambo's and cars like that and also a custom paint and airbrush shop . so do the gear boxes i have in my race cars whine yes ! is it because it's from the way the straight cut gears are meshing ? from what i was told yes ! part of the reason for that is also because they are solid mounted to the chassis along with the motors so ever bit of noise gets amplified from the motor and trans and goes thru the hole car . |
Ornery Bastard
But since you seem to have an irrational dislike of Harleys let's look at other manufacturers. Honda uses a mix of helical-cut and straight-cut gears in the Goldwing with a sequential transmission, as it did with the Valkyrie. Triumph uses helical-cut gears in the transmission for the Rocket III. The simple fact is that modern cruiser motorcycle sequential transmissions use helical-cut gears, both for noise reduction purposes and for strength due to the high torque loads at low RPM. Helical-cut gears are stronger and quieter and it's completely possible to build a sequential gearbox using helical-cut gears no matter how much you try to wiggle out of that fact. The continued use of straight-cut gears in low-torque bikes (and yes, even a 600cc super-sport is "low torque") is largely a cost-saving maneuver because the greater strength of helical-cut gears is not needed. Straight-cut gears are often used in custom racing applications chiefly because they are cheaper and easier to produce which outweighs the disadvantage in strength. Straight-cut gears also do not create the same sort of side-loading on the transmission shafts (helical-cut gears will naturally want to "walk" laterally and, by doing so, they impose greater thrust loads on the transmission shaft bearings than do straight-cut gears), which is a benefit because it allows the shafts and bearings in a transmission to be lighter, something which is important for racing. Straight-cut gears whine, and you're right that they do so because of the way the gear teeth come into contact with one-another. No-one has contested that part of what you've said. However, your ancillary assertion that you cannot have helical-cut gears with a sequential transmission was patently ridiculous and you also made the absurd claim that you cannot perform a clutchless shift with helical-cut gears (OTR semi drives do exactly that a couple hundred times a day). Bottom line: Straight-cut gears whine like a banshee when subject to any significant amount of torque. They are quiet enough in sportbikes and smaller bikes because the torque loads are typically small (even supersport engines in motorcycles have relatively little torque and instead make their power by revving to 15,000+ RPM) and because the amount of ambient noise on a motorcycle tends to drown out the gear whine. The use of helical-cut gears is spreading even in motorcycles, however, and there is nothing in the design of helical-cut gears themselves that would prevent their use in a sequential transmission nor is there anything that would prevent the ability to perform a clutchless shift. The difficulty of a clutchless shift in modern automotive transmissions is due to the design of the synchros, not to the type of gears used.
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) Last edited by AaronM; 01-16-2013 at 12:29 PM.. |
Incorrigible
Great discussion, I learned some things reading this thread. Good stuff.
The other day I was watching an in car video of Sean Edwards racing a GT cup car (997) on the Nordschleife with a picture-in-picture view of him driving with a sequential trans (or Porsche's version, I do not know post 1989 911s very well). I have to admit, the gear noise drowns out everything else, but I love the sound. But then it was not reverberating in my helmet at high volume. Search youtube for it. Racemedia.tv Jeff
1988 951 all track modded and angry, 2002 Boxster '88 924S, '65 912/911, '86 951, '79 924, '85 944 N/A, automatic - all gone. "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a concours field. |
Incorrigible
Here it is.
Porsche 997 GT3 Cup Sean Edwards Onboard VLN 5.Lauf 2011 Nürburgring Nordschleife - YouTube
Ornery Bastard
The process you should be using: (1) Clutch pedal down (2) Gear lever out of 4th and into neutral (3) Clutch pedal released ("up") (4) Blip throttle to appropriate RPM to speed up the input shaft (5) Clutch pedal down (5) Gear lever into 3rd (6) Clutch pedal released ("up") again smoothly with RPM close to where it would be for the speed you're at in 3rd
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) Last edited by AaronM; 01-16-2013 at 03:08 PM.. Reason: Typo |
Incorrigible
I used to have a 1953 Dodge M37 (military powerwagon essentially) and all shifts using first and second gears required double clutching. First and second were non-syncromesh. Later trucks did have all 4 gears with syncro.
You sort of get used to it and ot becomes fairly natural with time.
AFM #725
"How did they live back then"
dkbautosports.com
this is just to funny ! just like i did not state that you could in no way have a helical cut gear in a sequential gear box but the simple fact the most are not helical cut gears is just that a fact ! the simple fact that a side cut ( helicut gear ) is not as loud is the reason why they use them for say turing bikes and in some street cars . now this is right from my engineering friend at quaife . they use a straight cut gear because the there strainght . the teeth have more mating surface on the flat part of the teeth . i tried to up load the photo from tommy at quaife but can't seam to from my email . like quaife stated it has nothing to do with the cost it only has to to with strainght . so last night i pulled the lower case off the little under powered hayabusa that we are installing into a car for a customer . it's real funny how that motor too has straight cut gears . even though they (bike manurfactors ) only use straight cut gears on the little under powered bikes . like on very motorcycle that i have ever seen that gets raced and was built for racing . like the gsx-r , r1 , busa , zx , . as a racer for 35 plus years not that has raced for two car manfactures and own and race a 962 , two classed in GT1 948's ,spec 944 , ITS 944 , hill climb 944, F1000 , sport racer aka lmp2 , itb golf , and a DSR car . the reasons why your rev matching is not to over load the drive line on your down shifts and also unbalance the car . you should use you brakes only to slow a car for speed . by just dropping down into the next lower gear with out bring up the rev's to macth the road speed will put undo stress on the cars clutch 1st then it goes thru the rest of the drive line on your car . then when it comes to the balanceing of your car your doing that on every part of a track with your car on all 4 of it's wheels . this is why smooth is fast ! as a race instructor i always press upon my students to be smooth in your driving inputs . when your not thinking your going fast you most likely are going fast . again balancing the car and being smooth doing so is fast . so by not rev matching you are up setting the balance of the car . i should make it clear that i'm talking in the general terms ! i do not rev match all that often my D-sports car or the two with the quaife sequential gear boxes as there is no real need to do so . you see i just took it for granted before that we were talking about race cars and the gear boxes they use . but in typical forum style you always have to have some one that has never raced a car with a sequential gear box or i would bet never even drove a car with one telling you just what you said is totaly wrong and then want to get into a debate about it . as for me i will always listen to a engineer to what and why they do what they do and for the reasons they do so . because of the types of cars we work on in my body shop i get to drive many cars with paddle shifters . they really suck on the street ! there all very jerky at low speeds and tend to get confused . many do not want to down gear untill they want to even if you keep clicking the paddle to do so . so the bottom line is still the same sequential gear boxes tend to totally suck for street driving ! |
Ornery Bastard
And that still doesn't change the fact that this is wrong. You absolutely can shift without a clutch in transmissions with helical-cut gears, even in non-sequential gearboxes. The pieces that make clutchless shifting difficult on street transmissions are the synchronizers and the baulk rings, NOT the type of gears used. If you built a fully-synchronized gearbox with straight-cut gears, it would be just as difficult to shift without a clutch as the typical helical-cut street gearboxes. Quote:
The noise of straight-cut gears is because the gear teeth "crash" into full engagement and this places significantly more strain on the gear teeth. With helical-cut gears, the engagement is gradual across the surface of the teeth which reduces or eliminates the sudden "crashing together" of the mating surfaces. This is why helical-cut gears are quieter, but it's also why there is much less strain on the individual gear teeth. Additionally, helical-cut gears tend to have more teeth engaged at any given time because of the helical shape of the cuts. This further distributes the load and reduces the stresses experiences by any single gear tooth. Given the same diametral pitch and construction materials, a helical-cut gear will always be stronger than a spur gear because the helical cut gear will have a larger surface area in contact with the driving gear. As mentioned earlier, helical-cut gears create lateral thrust, however, and some energy is "wasted" because of this. In addition to the greater thrust loads on transmission shaft bearings, this also generates extra heat (bad in racing) and increases the amount of energy "lost" between the engine and the wheels (also bad in racing). Now, you can alter the diametral pitch or build the spur gears out of stronger material to compensate, but all else being equal, helical-cut gears are stronger. Quote:
(1) Straight-cut gears are typically used in racing, for the reasons I've outlined in previous posts. Simply saying "the racing transmissions I've seen have had straight cut gears" does not in any way contradict what I've said. (2) There is a difference between "low torque" and "underpowered." A ZX6R, stock, makes about 130 horsepower, that's pretty powerful. However, it only makes 52 ft-lbs of torque at the crank. For comparison, my "low-power" Sportster makes 77 ft-lbs of torque at the crank. Even though the Harley has less than half the horsepower of the ZX6R, it is putting 50% MORE torque load on the transmission, which is the true load factor. Motorcycle racing engines tend to have low torque and high horsepower. Quote:
This has never once been in dispute.
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) Last edited by AaronM; 01-17-2013 at 12:49 PM.. |
dkbautosports.com
so you your self just assumed some thing ( about the HD's ) .
i also assumed the being of the post was just about racing sequential gear boxes . that is because that is what i'm around so it's the 1st thing i think of when it comes to cars . if the post was about motorcycles then it's some thing totally deferent . but for all that matters there is such a low percentage of cars with them and they are totaly useless they are not worth talking about . what i should say is it's not the gear in it's self that is stringer because it's a striaght cut but the GEAR BOX it's self that is stronger . there is more mating serface to the helical gear in it's self but it's in the total design of the GEAR BOX it's self that is the down side to them . the have to be built bigger and stronger to handle the thurst loads of the gears them selfs . then as many know with a many street trans synchros are notorious for failing . helical geared transmissions that i know have synchros . we all know the helical gear in it's self is strong but the system is weak . this is why us people that race will change out the weak and heavy helical geared transmissions for the stronger and lighter sequential gear boxes with the straight cut gears . most are like the ones i my cars are 1/3 lighter that the halical type gear boxes . the reason you see so many up grade kits for car transmissions that go to striaght cut gears for cars like VW/audis , acura / honda , toyotas and so many other cars is for just that an up grade . a gear is much stronger than a synchro that is the 1st plus the next is you do not need a chutch to do your gear changes 2nd plus . the gear box is lighter 3rd plus the gear BOX it's self is a stronger unit making them more durable 4th plus . the down sides are they are loud they are clunky you can not get lazy in your shifting . the simple fact that all racers that want an up grade for there transmissions go to a straight cut sequential box is just that a fact . i was just talking i a general term when i did state than all gear boxes have straight cut gears . no not every one but most all do in the car racing world . my D-sports car with a mild build gsx-r 1000 motor dynoed it 163 HP and 92 TORKS . my F1000 car never put on a dyno but the guess is much more than that . a 2009 XR1200 HD torque is 73 FT LBS . WITH 90 HP got the spec on line a 2009 busa 99.6 FTLBS torks and 162 HP got thw specs in on line . but this being a car forum and not a motorcycle forum the gear boxes are not the same and not in any way what was asked about . so the person that did the posting wanted to know about cars not bikes . so some are thinking about motorcycles and taking a comment stated and thought it would be a good idea to at them into a mix with all the cars too . now getting back to talking about cars only and leaving other forms of transportion out . |
Ornery Bastard
I give up. I'm tired of wading through your brutalization of the English language just to point out what's obvious to everyone else.
The points I've made are correct. Helical-cut gears are stronger, but they produce thrust loads on the transmission shafts which causes problems in racing applications. Helical-cut gears are used in many street sequential transmissions and helical-cut gears do NOT in any way preclude the ability to shift without a clutch. I'm confident that my points have been made and that a neutral third party can easily see which of us understands the engineering principles in play.
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
