AFM #725
Grounds cleaning
So what are all of your guy's opinions on how to best clean electrical grounds. I know the old electrician's trick to use an eraser, and that worked great for my window switches but doesn't seem practical for the bigger grounds on the rest of the car. Fine sandpaper?
Also, is it true there is a ground for the instrument cluster up under the dash? I'm going to pull the instrument cluster soon, and try and clean all the electrical contacts and the grounds behind there.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
I use scotchbrite pads, they work really well.
I don't recall seeing any grounds behind the cluster. Any picture of where they would be? I had my cluster out to change the odometer gear.
1986 944 NA Sapphire Metallic http://944porsche.blogspot.ca/ |
AFM #725
Ugh there's a public Facebook album that shows the main grounds but I can't find pictures of a lot of them. An actual photo helps a lot more than the diagram
That Guy
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
AFM #725
Thanks Duck
I used brake cleaner, a wire brush, and steel wool on the hard to reach ones to clean mine. I've never heard of the eraser thing.
AFM #725
Pops was a Nuclear Engineer/Electrician's Mate, he told me years ago and it really does work quite well. I think there are better solutions for tough corrosion though.
AFM #725
85/86 models only![]()
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
AFM #725
Haven't seen the top one, thanks! Maybe I'll actually be able to find them lol
Mein Gott!
I used fine sandpaper and a small wire brush about the size of a toothbrush. Took to all the grounds except for the dash and it literally solved a non-start issue. Also, the interior light & buzzer started operating again when opening the door after this. The weird thing is they didn't look all that bad. One of the most rewarding hours you can spend on your car. Everyone should do this every year or so on these things.
Johnny 1987 944S 1984 944 (R.I.P.) 1972 Triumph TR6 - 100% trouble free between breakdowns 2003 BMW 325xi |
Oh man...What now?
Does anyone use a corrosion stopping liquid after you clean them? Years ago I ran into a mechanic for Chalk's Airline in south Florida. In our conversation I asked what they used to fend off sea salt corrosion on the sea-planes and parts. I've got it (the liquid) in storage but I believe it was called Corrosion Guard. Comes in a small silver can with green lettering on it, I believe. It's not aerosol but a pump spray. I used it on my car, the Jeep various outboard engines and never had any more corrosion problems. I also use it on the anodes on my battery(s).
Me and Porsche's go together like cocaine and waffles. Those don't go together. Well, peanut butter and women. Don't you mean jelly? You put jelly on women? (Ricky Bobby, Talladega Nights) 1985.5 944 Alpine white |
ASE Master
I am a big fan of Caig DeoxIT. Loosen up the ground, spray some DeoxIT on there, wiggle the wire around and tighten it up. Done. It also has properties that keeps corrosion from reoccurring. Years of Italian car ownership have made it an essential. Spray it inside of inoperative switches, work the switch a few time, fixed. Works a treat inside of wiring connectors on an old Fiat! Mine is 42 years old, all the lights are nice and bright and everything works!
1989 944S2 (sold after 11 great years) 1980 911SC Weissach (bucket list car) 1975 914 1.8 (future restoration) 1993 968 Coupe 6 speed (new acquisition) |
Mein Gott!
Vaseline.
I used a wire wheel to clean up the bolts, and sand paper on the tabs and chassis until I can see clear copper.
Regards Dave
'78 911SC Targa (Back In Action!) '00 996 Carrera (New kid on the block) '87 944 (college DD - SOLD) '88 924s (high school DD - Gone to a better home) |
Also I can't say I have had any rusty ground problems on these cars due the high quality of the metal. I have had to tighten a few up, though. Loosen, spray with penetrating oil, and then get them good and snug but don't snap anything off. I have seen corrosion problems on the small positive battery cables and on the main starter connection serious enough to need a little filing. |
I use "electrical contact cleaner" and a cloth if they are not too bad, works great on relays etc if you spray it on and pull them in and out a few times. Sometimes I lightly sand them but try not to if they are not brass. You can cover them in nox grease to stop corrosion.
Sometimes just pulling connectors on and off works fine. I recommend twisting all the HT leads, can lower the resistance and improve the spark. I work on military communications systems (including custom vehicles) so can access some cleaners and good advice!
1987 944 Summer 2006 E90 Winter |
AFM #725
Pretty much everything works in my car. But the gauges can be kinda bouncy and I've heard cleaning the grounds back there and the connections fixes a lot of the weird bugs. I have to pull the cluster anyways I have a replacement volt gauge. Now that I have working oil pressure I'd like to know the voltage lol
On aircraft we use a sealant (called PRC) to encase the connections of grounds and bonding jumpers. It's a 2 part compound, and when it cures it becomes hard and rubbery. This stuff is actually used everywhere. It seals panels and windows for pressurization, fills gaps for aerodynamic smoothness, etc...
Long story short, encasing the grounds in silicone should work.
Get yourself a golf club cleaner brush. It's wire on one end and just very stiff bristles on the other. I use the wire to get any heavily corroded/built-up areas knocked down, and the stiff bristles for getting it smoothed/cleaned.
Guy '87 944 (first porsche/project car) |
