Interesting...does the passenger side switch also stay operational? All the window switches are fed from relay G7, so if that stuck closed due to welded contacts, the windows would stay 'live'. However, all the switches would operate unless you had a wiring fault or a bad passenger window switch on the drivers side as that is the one that then feeds the passenger side switch. There will be no drain as there is no load. I would check G7 first...remove it and see if the windows operate. If they do, then you have a further wiring fault somewhere. If they dont - it could be the relay is stuck.
Porsche - accept no substitute
Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project
Black 1987 944S - Gone but not forgotten
Metallic Black 1980 924 - Those were the days....
Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began!
