OT: socket (torque) wrench attachment name
(I considered posting at the OT or general lists, but posted here anyways...)
I am asking for hints as to the name of a tool because I am having difficulty searching for it online (snap on, google and all that).
It appears be a torque wrench extension that is not a crowsfoot. it well could be an "obstruction" extension. below is a bad photo of the manual I saw it in.
for reference the torque wrench ball detent end is shown lining up with the hole on the extension, then the hex head would be at the furthest left. the outline of the extension is weak, I know. I can get a better shot if necessary...
I would be attempting to torque the bolts on the cam housing gasket cover with this extension, while bypassing the need to remove anything behind the cover - I know it should take only 5 minutes, and I already started a thread a while ago where some good discussion covered this topic, so might consider merging/going to that thread instead of this one.
Old 02-25-2013, 12:43 PM
Can you get a picture of the writing next to the picture? There may be a clue there...
Old 02-25-2013, 04:03 PM
Andrew Gawers' Dad
CHICKS's Avatar
I know what you're talking about, and I just read about it. Can't remember the name, but I saw it here in the tool section a few days ago: The Garage Journal
Old 02-25-2013, 05:27 PM
Without reproducing the manual (yet) of this Craftsman 3/8" drive torque wrench, i can say there's mention of "threaded tubing fasteners"
Old 02-25-2013, 06:12 PM
Site looks good, ill check it out thanks!
Old 02-25-2013, 06:13 PM
Do a search for TORQUE WRENCH ADAPTERS on the internet. All kinds of options available. I've used these since the '70's, but most people never even heard of them.
'86 944 Turbo
You have to be a masochist to love something so frustrating.
Old 02-25-2013, 06:59 PM
I just tried this.
so the name for a wrench adapter that goes on a torque wrench in fact is... wait for it... torque wrench adapter.
I suppose the subtlety is that the "wrench" term either refers to the adapter, or to the torque wrench itself...
thank you Pops944.
Old 02-26-2013, 11:26 AM
voo-doo's Avatar
I've always called them "dogbones".
Old 02-26-2013, 03:23 PM
This helped, thanks. I think it might have found a discussion on GJ that CHICKS mentioned.
It is tricky searching with these terms because they refer to more than one object.
Old 02-26-2013, 06:14 PM
gtroth's Avatar
Something like this:
1995 993C4 guards red
1988 944S alpine white
Old 03-09-2013, 07:36 PM
AFM #725
Gawernator's Avatar
Wow. Cool. You would need one for all the different sizes eeek
Old 03-09-2013, 09:34 PM
Volhv's Avatar
I use them at work all the time.
Keep them at 90 degrees to the torque wrench in order to apply the correct torque.
I call them torque adapters, but I've heard dog bone also.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 03-10-2013, 01:31 AM
I think I need a crescent end - the box end thickness is too much on the rear cam cover. - I have found plenty like you all show - how about a crescent/open end? All I found in that vein are custom wrenches from Belknap.
Old 03-10-2013, 06:00 AM
Incorrigible
ditch68's Avatar
What he said. If you have the "dogbone" anything but 90° perpendicular to the tq wrench, you are adding torque and will over torque.
I use those at work all the time. We just call them dogbones, but Im pretty sure ot is called a "torque adapter".
Jeff
1988 951 all track modded and angry, 2002 Boxster
'88 924S, '65 912/911, '86 951, '79 924, '85 944 N/A, automatic - all gone.
"It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a concours field.
Old 03-10-2013, 07:11 AM
Volhv's Avatar
Ahh... that would be a crow-foot.
File:Crow's foot wrench.jpg - Wikipedia, the free encyclopedia
Same as before.... 90 degrees.
Old 03-10-2013, 09:14 AM
gtroth's Avatar
Get em as you need em. I have exactly one - for the lower oil drain plug on the Carrera where a socket won't fit.
Might be good to get a 10mm and 13mm just in case.
Important tip, Vol.
You can use them end on if you use the conversion formula
Old 03-10-2013, 10:29 AM
Quote de Bukowski
AFAIK crowsfoot fittings never have the length extension desired for this application, nor do I know of a separate extension of the wrench handle axis to achieve it.
Old 03-10-2013, 06:11 PM
