AFM #725
I still need to watch Office Space LOL
The up shift light. It comes on around 2500ish RPM to say, "hey shift now and save gas!" and again at like 6000ish RPM to say, "WTF are you doing?!?! SHIFT YOU MORON!!!! Your engine is about to grenade!!!"
Yes you do. Make sure you watch the real version and not the censored TV version. Last edited by Chunkerz; 02-27-2013 at 06:17 PM.. |
AFM #725
When you drive with a light foot and go conservatively and slower it comes on around 2,100-2,300 lol
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
To do any damage (from what I understand), you really need to run into oil starvation issues. And that only arises from prolonged time on the track, i.e. multiple hours where the car is above 4k RPM all the time.
Most of the LeMons entrants who run 944's run into oil starvation only after several hours. Some go the whole way. It would probably be impossible to run into this issue on the street. Unless you drove everywhere at redline in first gear. Quote:
It might be something that runs like a computer for an automatic transmission, but rather than doing any shifting it just shows a light. Take care! Last edited by FrenchToast; 02-27-2013 at 07:16 PM.. |
AFM #725
So, I'm not using much throttle now am I
Custom User Title
What's all this 5th gear stuff? I've never had my 951 out of 3rd (hardly). I shift into 4th at 105 MPH. Only one time, I got on it in 4th - I was racing a VW GTI - and buried him as soon as I hit 100. By the time I was at 115 MPH, he'd dropped way back, so I got off it. I've never had the balls to go all the way to 5th.
I have to admit I was surprised, because at 115 MPH, at about 3,000 RPM in 4th, the car was pulling like all get out and subjectively, it didn't feel any different than say 60 MPH. I was really impressed. My NA, I love to play with, too. There's a tight, 180º turn at work, and I love sliding around it at about 30 MPH, tached out to about 6,500 RPM in first ( I come into the corner at about 40-50 MPH in 2nd and downshift as I start the turn). These cars are made to be driven. If I break something, I'll fix it. What fun is it driving a Porsche, if you treat it like a Studebaker? Jeeze!
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
AFM #725
I'm not at that engine pulling level yet, lol I'm just trying to rebuild my injectors and not have them leak.
AFM #725
I also like how not a soul answered my question but this became a flame thread on shift points lol.....
the simple answer is: crap in your injectors.
this is not a job to be done at home. even at the pro shops, sometimes it takes cleaning them twice. i just had to do that with a set. i sent them to one place (not my usual one) and they did not get fully cleaned, so the flow rate was off. they went out to my usual service place, and now they are perfect again. |
Incorrigible
I do cruise in 5th on the freeway at 80-82ish (speed limit 75) just to save gas if I drive it to work. But sheesh,I flog that thing. Every onramp is a full blast like out of corner 5 at Road America! I heel toe and drive it like it was meant to be. Really, why have one of these if you dont use ot like it was built to be used? Yes, IT WAS BUILT FOR THAT! These cars will amaze you at the limits of their potential, have fun with it! Safely, of course, but you get the idea. Jeff
1988 951 all track modded and angry, 2002 Boxster '88 924S, '65 912/911, '86 951, '79 924, '85 944 N/A, automatic - all gone. "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a concours field. |
Incorrigible
![]() Toast, my '88 924S had CASIS. Jeff
1988 951 all track modded and angry, 2002 Boxster '88 924S, '65 912/911, '86 951, '79 924, '85 944 N/A, automatic - all gone. "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a concours field. Last edited by ditch68; 02-28-2013 at 06:25 AM.. |
You mention that it ran fine the second time you started it up. And that you used some carb cleaner and silicone spray. Possible that some residual chemicals needed to be burned off. Drive it more and see if the behavior continues.
1984 Porsche 944 - Mathilda the needy 2014 Audi Allroad - daily driver |
Custom User Title
Sure I do use 5th on the freeway, cruising along at 70. But that's about it. If I'm driving local, it hardly ever gets out of 4th. |
It should be at least 5k for a stock tranny, has yours been modified?
AFM #725
Hate to rain on the parade but I think my injector #1 is FUBAR? I re sealed and after a couple re seats it stopped leaking. Now it's leaking again and maybe worse. From the hole where it goes into the manifold. I used pure silicone to lube the o rings and nothing looks torn. No leaks from the rail or other injectors. I'm starting to think from what I've read that it's leaking at that joint where the tip meets the body? Amazed my car isn't on fire yet and I'm gonna pass out from all this gasoline. Idk what to do
Ornery Bastard
As far as a blanket "never under 2,000 RPM" rule, that's just not a thing. The RPM at which an engine is lugging varies based on load, amount of throttle applied, and the gear you're in. Running at 1,000 RPM in 2nd gear is fine. Running at 1,000 RPM in 5th is definitely not. That said, I certainly wouldn't be shifting into 5th at 35 mph with my 951 (45 is my lower limit for 5th gear, and that's only on level ground when I'm not going to be accelerating), but I believe that the 951 has taller ratios than the NA cars so the comparison might not be terribly accurate.
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
Custom User Title
Thread Tools | |
Rate This Thread | |
