Can someone explain this
So, past day or so I did some decent surgery on my 944. I removed the fuel rail and manifold. Rebuilt the injectors with Rennbay's kit. Painted the manifold black. Replaced AOS seals. Cleaned ICV with carb cleaner and sprayed some silicone Teflon in there. Replaced front and rear ICV hoses. Replaced AOS breather hose. Replaced oil cap o ring. So last night I put it all back together and prepared to standby for engine fire, luckily I wasn't completely retarded and no leaks at the rail or injectors!
Last night I first started it up. For like five minutes I idled and watched for leaks. There was smoke of something burning off, probably water. It went away. So I first started it up. Idling strong at 950 RPM. Then I went for a test drive. When I went back to idle it would dip down below to as low as 550 then bounce up. If sitting idling it would bounce occasionally if I revved it and let go. It would drop Low then come back up. I used jumper cables from body to engine and that didn't change anything really. So I said oh well and went to bed. This morning it started perfectly, idles perfectly and drives stronger than it did before. ????? Biggest difference I noted is when shifting into fifth gear at 35 MPH. Before it would bog down a little and wouldn't accelerate much below 40 MPH in fifth. Today driving it powered through at 35, I was quite surprised. |
My only explanation thus far is "your car was in a bad mood last night" lol
So my gremlins have relatives! Just a question, why do you shift into 5th gear at 35 mph? I'm there at about 55/60 mph. Just ask'n.
I'm apparently a grandma. I usually shift around 2k RPM. Going onto an on ramp I shift at like 45 MPH. Maybe 40 MPH once the engine is warm but when it's still cold I like to keep the RPM's low...
Oh, God no, no one drives as carefully as I do in a 28 year old car. I don't push myself as hard any more either. Mine bogs in higher gears at lower speeds.
I'm only just turning 20... Maybe I need to live up to my boy racer stigma better? For Rasta Monsta's sake. To be honest dude, I did go to 3.5k in third today to beat a light before it went yellow. Badass. ;) Ipagolf, maybe you have some tired parts?
If you read the owners manual you would know you're pretty much never supposed to operate the engine below 2000 rpm.
Guess I missed that page.
When I get up at 4:30 every morning, everything about me feels like old worn parts! I just don't push the old guy (the car). I have a lot of fun with it, but I don't want to break it.
I have to shift at over 4000 rpm - I'm just addicted to the exhaust noise when you do it.
I tell my boys, some are older than Gaw that they never need to go over the speed limit, just get to it quickly! |
'Loading' the engine (i.e. in gear, driving) below 2k usually does more harm to the engine than people think. It's really not good to drive an engine like that. There is no torque and the engine really struggles quite a bit. I've never understood the people who brag about having never taken their engine above 4k - that's not good. Nothing gets properly warm. Take care! |
Economy? What?
Lugging the engine under 2k where it has no torque, and therefore making it work harder than it should, probably burns more fuel than driving it above 2k where there is torque.
Take care! |
The gnome and elf-powered CASIS light comes on at like 2,100? In most gears
Did you put the restrictor back in the hose from the TB to the J-boot?
Gaw, you need a heavier right shoe. The light comes on at higher revs if it thinks you want power not economy.
Another recommendation - buy a Land Rover as well, then you won't worry about the 944's economy!!!!! |
I need mine to last lol!
My reasons for not exceeding 4,500rpm include - not wanting to throw #2 rod. - not needing to use all 168 bhp. ( M44/09 with Bursch headers & AutoThority chip ) - by 4,500 I'm already quickly passing the other cars in the lanes beside me. - a desire to run this engine another 260k. - by 4,000 I'm pretty much already exceeding most posted limits. Not flaming; I'd love a chance to wring out a 944 to redline... just not my 944. Cheers Mike |
| All times are GMT -8. The time now is 06:37 PM. |
