Patrick
There's definitely a sweet spot when the car pulls nicely.
1984 944 NA, constant tinkering 1983 "Beastie" - Safari Build |
AFM #725
I will say if I am feeling rich and adventurous I definitely shift closer to 3k, I do love the engine sound and the power, I actually have pulled away from traffic a few times with minimal effort. However I love being economical, lol. The only gear you need to shift higher than the low 2k is into fifth
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Explanation:
Your car is not used to the new fuel ratio and control. Try and clean your TB if you haven't. Anything that has something to do with the Fuel/Air Mixture Ratio, You wanna make sure is working to the full potential. Other then that, just drive it a couple times and see if it acts up anymore. If anything you should make sure you unplugged the Battery for a while. I would suggest 12 Hours. Or Over night so your Computer re-learns everything and re-learns your Rail/etc. P.S. I would never use silicone Teflon of a sort. Just in my own opinion, the smoke was from the cleaner you sprayed. Was just burning off the motor. gL |
AFM #725
To recap on what happened, the smoke was water from me spraying down the engine bay earlier in the day. I have four new rebuilt injectors on, the TB is very clean and I rebuilt it with the Arnnworx kit. (Spent hours cleaning and painting Tb and intake manifold). The problem was a combination of one, leaking fuel injector, two, ICV needing to burn off the stuff inside which happened after a day of driving and three, tapping the ICV one last time and making sure the connector was on tight. Currently my 944 is driving like a dream.
Glad to hear!
Thread Tools | |
Rate This Thread | |
