Odometer stopped working
Simple question...my speedometer is still working but the odometer is not. Where might the problem be and what should I do to diagnose and fix it? It's a 924S so the early style dash.
Currently have: Guards Red 1987 924S 16v -- Light Blue Metallic 1980 928
Gone: Minerva Blue 1979 928 -- Gray 1985.5 944 -- Black 1989 944 -- Black 1984 944 -- Black 1987 944S -- Alaska Blue 1974 914 1.8 -- Guards Red 1983 944 -- Guards Red 1987 924S -- White 1988 924S -- Maraschino Red 1987 944 Turbo -- Beige 1981 924 -- Red 1984 944
Old 08-07-2013, 08:14 AM
Proprietoristicly Refined
John_AZ's Avatar
Usually a new gear.
OR you may get lucky and just have to slide the "loose-skipping" gear back in place and glue.
Be careful not to cross thread the speed O cable connection on the back of the speedometer.
Also, there is a delicate connection from the speedometer to the UP-Shift indicator on the dial next to the speedometer. This is the Hall Sensor connection.
DIY--Note Pelican sells the gears---Buy from Pelican
http://www.944online.com/pdf/944_Early_Odometer_Gear_Replacement.pdf
GL
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 08-07-2013, 08:35 AM
Thanks. I'll take the gauges out and have a look at it, and return if I have more questions.
Old 08-07-2013, 10:15 AM
John_AZ's Avatar
I did not have to remove the "needle" to fix mine. The gear slid sideways. I put a drop of epoxy on the shaft to keep it in place ----5++ years ago and still OK.
J_AZ
Old 08-07-2013, 10:18 AM
AFM #725
Gawernator's Avatar
John's a lucky one in that case. Some of us have performed a full repair and still get issues..
Old 08-08-2013, 01:00 AM
