Can 924/944 Transaxles be run upside down?
I am curious if the 924/944 Transaxles ever have been or could be run upside down, similar to some of the 911/930 stuff?
Dealer for Cibie & other Period Fog/Driving Lights, brackets, Corbeau Seats, Fuchs, Torque Thrust, Minilite, Coromodora and other Period Alloy Replica Wheels GregGearHead com Ask me about Replica Fuchs (Even Deep 6 & 7R) wheels! |
Yes, but you may have problems sealing the transaxle so that it doesn't leak.
Good luck, George Beuselinck |
Yeah, I would assume vents might need to be re-routed/relocated, but wondering about oiling, etc.
Should be no problem... there is no oil pump, just a bath of oil.
Potential problems that I can think of are as said above, sealing, venting and shift linkage. Also you would have to flip the diff
Incorrigible
And the fill/drain plugs, but the gearset/diff is designed to sit in a specific depth of oil bath so the fill level would have to be re assessed anyway, of course.
Jeff
1988 951 all track modded and angry, 2002 Boxster '88 924S, '65 912/911, '86 951, '79 924, '85 944 N/A, automatic - all gone. "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a concours field. |
Thanks - good points all. Depth of oil bath when right and upside down is probably pretty important. I was wondering about the mainshaft, too, running submerged vs. splash lubricated? I am not a trans guy so don't know if this matters.
Awesome point, and really, the source of my question. I want to be able to run this trans in a rear-engined application, so hoping this will be a good solution to finding a strong, available, and ratio-correct trans. Flipping it will allow 5 forward gears when rear engined and flipped over. We'll see....
How would you flip the diff in this type of box?
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
My understanding is you can not flip the diff in this type of box, hence my inquiring to flipping the whole transaxle, to get the same result, albeit with different height for CV flanges and other issues, but, a possible solution.
