Frankly my dear....
rhett's Avatar
Porsche Crest Heater control switch LED upgrade
Hi, this DIY tutorial shows you how to replace the rather dim bulbs in the heater control switches for brighter LEDs. To carry out this procedure you do need to be a bit ‘electronically’ or ‘electrically’ minded as it involves de-soldering and re-soldering small parts. If you are at all unsure about any of the steps, then get someone who has the necessary expertise to help. Obviously, what I provide here is guidance only (it is how I did it), I cannot guarantee that you will have the same degree of success.
You will need:
Soldering iron with small tip
Solder
De-soldering tool
Small pliers and side cutters
Small screwdrivers or similar.
Replacement LEDs with suitable ballast resistors ( I used 3mm high brightness LEDs with 470ohm 0.25W resistors)
12V supply for testing
Firstly, you have to get the switches out of the heater control and this can be a bit of a struggle. There are two distinct variants of the heater (early and later), I am unsure about when the change took place but it must be around late ‘88 onwards. The early controls had the switches soldered in, the later had them mounted in sockets. To identify the two types look into the front lower slider, if you see the circuit board as shown, it is the early type, if you don't see a board but a row of solder joints, it is the later type.
If you can get hold of a later unit, do it..as it is so much easier to work on. If you can do this upgrade on a spare and not the one fitted in your car, I recommend you do that too, if possible.
Either way, proceed as follows:
1. Carefully unclip the heater control fascia panel.
2. Remove the slider knobs and both rotary switch knobs.
3. Remove the securing nut and washer from the RH temperature control.
4. Remove the insulating tape that goes around the heater control housing.
There are 8 small plastic tags that hold the housing to the front panel, treat them with care as they can break easily..they are old! Basically you have to separate the housing from the front panel, so use a variety of small screwdrivers or similar implements to push the tabs down whilst easing the housing off. I am sure you can work this bit out. Remember, slowly does it!
If working on an early unit, locate the back of the switches and de-solder the switch contact pins (7 apiece). You may have to remove some plastic sealer to gain access to the contacts. Ensure all the contacts are completely desoldered as you will damage the circuit board pad if you try to remove the switch with any solder still attached. Do not to apply too much heat to the pads as they will lift from the board. This is where experience with this kind of work comes in handy…you know what to do without damaging stuff.
Carefully check that the switch contacts are free and clean of solder before attempting the next step.
If working on a later unit, you join us here!
1. Carefully prise the switches from the circuit board (or sockets) to separate the plastic front panel from the unit. Take your time here and do not use excessive force. If resistance is felt it could be a bit of excess solder on a switch pin. This can be trimmed off using a sharp blade, if necessary.
2. Once the panel is free you need to remove the switches from the panel, simply push down the mounting tags and carefully extract them from the panel. Again, you can work this bit out.
Now you need to open the switch, as follows:
1. Using a fine blade or similar implement (and extreme caution so you don’t injure yourself!), carefully prise the contact plate out from the switch body. Again take your time..do not use excessive force as you might break the switch body or the mounting tags. Either way, that would be a real problem when trying to get it all back together. Work on one side first, then the other until the plate pops free. There are 2 springs in the switch and they will assist in the separation, but they shouldn’t have so much pressure to send the whole thing flying apart. That said, just be ready when the plate does pop.
2. Separate the switch, noting how the 2 springs are located.
3. Remove the springs (for convenience).
The bulb closest to the edge is the tally indicator that shows the switch operation, the one closer to the centre is switch illumination. I chose a blue LED for illumination and a green LED for the tally – but this choice is entirely up to you.
Preparing the LEDs
Now, it is pretty tight on space in the switch so getting the LEDs aligned right and at the correct height is important, otherwise they might foul on the switch mechanism and your switch may not work. Also, LEDs are polarised, so getting them fitted the right way round is very important as they will not work if fitted incorrectly.
The common contact between the bulbs is the ground, this is pin 31 on the switch. Pin 1 is the tally light, 58 is the illumination. Therefore, the negative leads (cathode) from both LEDs have to connect to the common, the postive leads (anode) connect via resistors to pin 1 and 58.
If you are unsure about which LED leg is which, Google will show plenty of examples, and use your 12V supply and a resistor to test..
1. Carefully remove one of the bulbs from the switch by simply heating the solder and removing the bulb wires.
2. Measure the length of the bulb and wires (approx 14mm)
3. Cut the LED anode to about 4mm - see A below.
4. Cut one leg of the resistor to 4mm also.
5. Solder the resistor to the LED, do not apply too much heat as you could damage the LED - see B below.
6. Cut the remaining leg of the resistor and the cathode of the LED to match the length of the bulb - see C below.
7. Once the LEDs are prepared, give them a quick test with the 12V supply to ensure the leg with the resistor is positive. The LEDs should light.
Fitting the LEDs
1. Now, simply solder the LED in place, ensuring the polarity is correct - see D below.
2. Do the other LED, exactly the same, but a mirror of the first.
2. Once installed, connect your 12V supply negative to pin 31 and test the LEDs again by touching +12V to pin 1 and then 58. The LEDs should light in turn.
3. Make sure the LEDs are upright and no excessive solder is present.
4. Clean the switch contact pads (if necessary) using a contact cleaner.
Here are some photos of the above steps:
Reassembly
1. Replace the two springs into the switch plate and lower the switch body onto the plate. Do this very carefully to ensure the springs locate correctly (you will see how they are supposed to fit.
2. Squeeze the switch parts together until the tags locate on both sides with a ‘click’.
3. Operate the switch to ensure it all works with no mechanical problems. Note, you may have to open the switch up a time or two to get it working just right if the LEDs are fouling. Be patient, it should all operate correctly when aligned, etc. Check the LEDs with 12V once again just to be sure!!
Then, do the other switch exactly as the first.
If you are also doing the other heater bulbs, use the same techniques (they are easier!).
Once everything is OK, reassemble the unit in the reverse order to the above procedure.
If you have tackled the other dash switches already, you are probably ready to take this on..
Hope this procedure helps someone with this task...take care!
PS. Here is what they look like when done (did all the others too):
Click here to download a PDF of this article
Porsche - accept no substitute
Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project
Black 1987 944S - Gone but not forgotten
Metallic Black 1980 924 - Those were the days....
Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began!
Old 03-10-2013, 02:08 PM
Thank you, Rhett, for making such a detailed write-up. I'm too fumble fingered now to accomplish this task. I'm sure others will have no problem. Highly recommend this be put in the DIY Section of Pelican for future reference.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 03-10-2013, 03:00 PM
AFM #725
Gawernator's Avatar
Great write-up man! If I ever have nothing to do and a bunch of free time....
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 03-10-2013, 03:23 PM
J1NX3D's Avatar
Nice!
https://www.instagram.com/kiwi944s3/
'86 944S3 conversion
- '94 968 3.0 engine
- 6 spd/LSD
- 17x8,17x9 Oz Racing Crono wheels
Old 03-10-2013, 04:25 PM
9FF 9FF is offline
9FF's Avatar
Thank you, that is a nice and wothwhile write-up. I'm an electronics geek and admire your patience! I know I have the ability to do this but having taken a few plastic switches apart and fixed them I know how brittle the old plastic on our cars can be, especially those retaining lugs. Taking that thing apart would scare me especially as a lot of the parts are nla. Just reiterating the op's statement for others who might think this is an easy job....be very carefull when dismanteling those plastic parts!
Old 03-10-2013, 05:11 PM
Frankly my dear....
rhett's Avatar
Hi guys, thanks for the compliments..! I was wondering where to put the topic? If someone could let me know where I find the DIY section of the forum - I will copy it there.
Nice thing about this type of project is you can do it indoors, where it is warm and comfortable..with tools that are clean. Heck, you might even keep your hands clean too! Also, you don't have to heat anything up with a blowlamp, hit anything with a large lump hammer, squirt release oil everywhere or lay on your back!
Hopefully, the next write-up will be the rear wash-wipe project I am working on at the moment. I have built a simple delay circuit for the rear wiper and obtained all the parts necessary for the wash system..so watch this space.
Old 03-11-2013, 03:17 AM
AFM #725
Gawernator's Avatar
No. I will do this laying on my back because this is a 944. Ownership is meant to be masochistic with these vehicles.
Old 03-11-2013, 08:09 AM
Frankly my dear....
rhett's Avatar
Lol...how very true!
Old 03-11-2013, 09:33 AM
ernie9944's Avatar
Nice DIY write up,agree with Larry that it should be add in the Pelican DIY section for next reference.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 03-11-2013, 05:06 PM
Hi Rhett, Can you put your write-up in a PDF Format so we can copy and save?
Cheers,
Larry
Old 03-11-2013, 06:03 PM
Frankly my dear....
rhett's Avatar
Hi Grandad#3, Yes, I will PDF the file and upload it. I think it has to be in a new thread rather than a quick reply...so I will look into doing that.
Old 03-12-2013, 03:16 AM
Frankly my dear....
rhett's Avatar
OK, here's the thing...I have produced the required PDF, but I cannot see how to upload it as an attachment to the BB. I have looked at the FAQs but although my rights as a user say I can post attachments, I do not see any controls that actually allow me to do it
When I click the attachment icon nothing happens, and the 'manage attachments' option mentioned in the FAQs is nowhere to be seen?
Any clues anyone?
Old 03-12-2013, 04:26 AM
Hi Rhett, Here is what Scott at Pelican sent to me. If you want, I can put the PDF on the Pelican server so that he (you) can link to it. People need to click the link and open it up (it wouldn't be visible on the forum page without clicking). If you want to do that, email the PDF File to him. scott@pelicanparts.com
Hope this works out for us all.
Cheers,
Larry
edit: from Scott. OK, I added the link to the PDF at the bottom of the original post. Enjoy!
Old 03-15-2013, 03:21 AM
Frankly my dear....
rhett's Avatar
Just to let all interested forum members know...Scott at PP has added a link to the PDF at the end of the original post.
Hope it is of use..
Old 04-01-2013, 12:46 PM
Volhv's Avatar
That's a pretty neat mod. Have you finished the whole dash?
I did the same thing to my Integra years ago. (don't judge me, I've had that thing since high school.... 8 years ) The thing that left me less than satisfied was the fact that leds are very directional, and some spots on the display are brighter than others. I could not get the evenness of factory incandescent bulbs.
How even is the light on the 944's display? A bit hard to tell. In the pictures you posted it looks pretty slick.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 04-01-2013, 01:00 PM
Frankly my dear....
rhett's Avatar
Thumbs up
Hi Volhv, yes, I have changed all the bulbs in the switches to LEDs with the exception of the hazard switch indicator bulb, but might try that at sometime as I have a spare to mess around with. LEDs are very directional and can give bright spots. To help sort out this problem I roughed up the LED lenses to diffuse the light and added several more LEDs to help even out the distribution. All this work if still very much 'work in progress' 'cos sometimes you don't really know how it will turn out until you try it... At present working on a EL backlight for the instrument cluster with red LED glow lexan needles. It's coming on well and I am producing a write-up for that too..should be available if a couple of weeks. Once it is all done, I'll post up some pictures.
Old 04-01-2013, 01:12 PM
Volhv's Avatar
Awesome.
One day I'll brighten things up also. For now I should st least get mine drivable. I have 0 compression on all cylinders due to a removed head.
Old 04-02-2013, 05:39 PM
Very Awesome post. Been wondering about how to do this upgrade.
Old 11-16-2013, 06:40 PM
rhett - what pins do you use on the back of the completed climate unit to test all of the lights?
Old 03-17-2014, 06:05 PM
plays with toy cars
sausagehacker's Avatar
I did this today for the early dash, no soldering was required. You simply pop out the bulb holder, remove the old bulb, and insert the new LED. Reassemble and enjoy.
http://i.imgur.com/HOQ56mw.jpg
1983 944 - modded everything
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317
'86 951 - under construction
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374
Old 03-17-2014, 09:17 PM
